oil pressure fluctuates when clutch pedal is down
Old 07-17-2013, 10:13 AM
Phozzy's Avatar
Exclamation oil pressure fluctuates when clutch pedal is down
well i looked into it and it seems like no one is having the same issue that i can tell.
i put a cam in and ever since i have been have weird issues with my oil pressure. when i push the clutch pedal in to come to a stop, the oil pressure as well as the idle drops then comes back up, sometime 3-4 times then equals out. also this will sometimes kill the car. also sometimes it runs like a champ.
i heard it could be in a tune (which i have not had done, im on tight budget right now)however i am worried that it might be internal issues.
also when i bought the car the previous owner unplugged the O2 harness, which drug on the ground and ate it up. i bought a new O2 and rewired it since it had no harness, i think i wired it up wrong cause i still get the trouble code. but to me it doesnt sound like that would cause such the issue.
just need some advice before i go spending money that i dont have.
Old 07-17-2013, 01:31 PM
outkast6991's Avatar
Oil pressure is dependent on rpm. Get your idle stable and if you still have oil pressure issues then start to worry
Old 07-17-2013, 04:44 PM
Phozzy's Avatar
alright ill see about getting that tune as fast as possible
Old 07-19-2013, 03:49 AM
FreebirdWS6's Avatar
other than your tune making oil pressure move your oil pressure sensor could be going out, just an idea cuz mine would fluctuate at idle in neutral but when i changed the sensor it fixed it
Old 07-19-2013, 07:23 AM
Old Geezer's Avatar
"i heard it could be in a tune"... You most likely heard correctly.
Old 07-19-2013, 12:30 PM
2000PewterT/A's Avatar
A tune will have NO effect on oil pressure, rpm effects oil pressure along with other things. If you have a fluctuating rpm you may have a slightly fluctuating oil pressure.
Quick Reply: oil pressure fluctuates when clutch pedal is down
