Ls3 water pump on ls1 block
I not running powering steering and I have bought the belt and pulleys I need to run it . But I have ran into a issue with the tensioner Everything lines up perfect but the top tensioner . It sticks out father than the rest , causing the belt to slide off . I used 5060548 belt with replacing the alternator pulley with a ribbed one . I'm using a ls3 pump on a ls1 block . I used 3/4 spacers to make the pump line up but now the tensioner isn't lined up
Grind the back side flat and square and make a 1\4" thick plate
bracket and bolt it to the back.
Drill it for the tensioner and mount it to the front.
It would require a longer belt.
