LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Stock injector size? VS. Deka 60's? (https://ls1tech.com/forums/generation-iii-internal-engine/1670238-stock-injector-size-vs-deka-60s.html)
Ironfreak Aug 20, 2013 09:14 AM
I'm building a motor for my bmw. LM7 with flat top pistons, 243 heads, GM hot cam, ls6 springs ect.... I got an intake from a 2000 SS but it didn't come with the injectors. Could I use the Deka 60lbs. and turn them down enough to feed a setup like this, or would they still be to big?
Is it time to go hunting for some stock injectors??
Thanks
DisasterpeaceWS6 Aug 20, 2013 09:48 AM
Thanks
I think #60 would be a little big for just cam/heads build. I have some #42 for sale if you are interested PM me.
Ironfreak Aug 20, 2013 10:52 AM
pm'd you. Thanks.
JakeFusion Aug 20, 2013 03:19 PM
The Siemens Deka idle about as well as 42s from what I recall. Just make sure your tuner has the file for them.
Ironfreak Aug 20, 2013 03:26 PM
See thats what I like to hear! I'm pretty sure he does, I'll have to double check.
Has anyone use the PSI connectors that you have to use when putting a ls1 intake on a truck motor using the truck harness? $35 seems like a decent price.
© 2026 MH Sub I, LLC dba Internet Brands
