PS Noise on cold starts? Maybe? (Video Link)
01 Camaro LQ4 with Ls1 Accessories.
On cold starts theirs a whining noise coming from the PS pump area. The noise doesn't change when turning the wheel but does from hitting the gas.(gets more violent.) The noise stops after a sound of what seems to be pressure releasing. This happens within 30 sec to a minute of idle/driving. After that I rarely hear it again. If I do hear it again I would describe the noise (listening from in the cab) as a dremel tool running under the hood followed by the pressure release sound. I've searched for answers but only turn up with the common questions about noises do to air in the system ext. this is no normal ps noise that ive heard. Any advice would be greatly appreciated!
Thanks for the reply's. I was leaning towards the thought of it being a bearing myself, I was only skeptical because its not a constant noise. Better to ask around than go into it blind and waste time. Ill be pulling the belt later tonight, I'll keep you guys updated. If not I will follow up on what the problem was once I have fixed it.
Yes that def is the air pump. They only run on start up the longest on cold start up and run until the O2 sensors come on line about 20-30 seconds. The noise is 1 of the 2 fan blade/squirell cages rubbing internally,,,,,,eventually it will quit making noise which will be followed a cpl days later with the check engine light as the motor will have died. I went to Fry's electronics and bought a roll of 20 gauge magnet wire and rewound My Moms' pump in Her Cadillac and it works great but unless You're into that kind of stuff I would'nt suggest You try that ,,,,they're only 200 bucks after-market
