Shims too little, no shims too much??
Old 05-03-2004, 02:03 PM
02WSsicks's Avatar
Default Shims too little, no shims too much??
Used the shims that came with the yella terra's, and it clanked like hell. Took the shims out and got about 1-1/4 to 1-1/2 turns of preload. That seem like much?? Only other option is to get 7.35 rods right?? And will that work??
Old 05-03-2004, 04:11 PM
George C.'s Avatar
Yella Terra told me that 1 to 1-1/4 is not bad. If you want to get them exact you can set them up in pairs (in/out). Each .0015 thick shim is about 1/4 turn. With this calculation you can get pretty close if you want to spend the time to do them all. Otherwise I don't think I would worry a whole lot either way.
Old 05-04-2004, 09:54 AM
02WSsicks's Avatar
HHmmm.... anyone else run this much preload without problems???
Old 05-04-2004, 10:57 AM
George C.'s Avatar
call Yella Terra... I did. Stock is 2 turns.
Old 05-04-2004, 06:20 PM
Brian2001SS's Avatar
I'm running a 1-1/4-1-1/2 turns. No problems. Stock lifters like alot of preload.
