243's or worked 862's? Is it worth porting 862's to flow the same as 243's? If I recall, the 862's have an even smaller combustion chamber than 243's, but they don't flow as good. I'm talking about putting them on a LQ4. Reason I ask is because my dad's Silverado has them, and if he wrecks it or the tranny blows up or something, could I throw the heads on mine after they've been ported? The motor will most likely have a cam, long tubes, and a good tune. |
I am curious to this as well. I have a set of 862's on my LS1 and know that they do have the smaller combustion chamber for higher compression. I believe Ported 243's will flow much better than ported 862's. I am sure someone will chime in with better info. |
Better port in the 243's vs. more compression with the 862's. The difference is probably negligible, however, some of the 862 casting were prone to crack and leak water. Those are the Casttech castings, which have the battery logo. |
Unless you get some hack-job hand port, you're going to end up spending 1k for a quality port job vs. ~400 for 243s. That right there would not be worth it to me unless I'm building some sort of racecar, at which point I'd just spring for the ported 243s for a few hundred more. For 1k, you can find quality ported 243s used on here that will blow the 862s out of the water. |
$1000 to port heads? For some reason, I had in my mind that it was about half that. I suppose it could be, for a crappy job. 243 it is! Thanks guys! |
Cnc porting is expensive because of the R&D and the tooling/machine needed to do the job.. Hey KCS, sound familiar? Lol |
$1000 to port heads? A random no name porter might charge you 7-800, and an amateur with a grinder prolly 4-500. |
Originally Posted by Burken01
(Post 17803995)
Cnc porting is expensive because of the R&D and the tooling/machine needed to do the job.. Hey KCS, sound familiar? Lol If it were me and I had a budget of about $400, I would go with the 862 castings without a doubt. For $400, I could have a set of 862's that would annihilate a stock set of 243 heads that just about anyone could replicate with the same budget. |
Originally Posted by 71K20chevy
(Post 17803940)
Originally Posted by KCS
(Post 17804199)
LMFAO, deja vu... If it were me and I had a budget of about $400, I would go with the 862 castings without a doubt. For $400, I could have a set of 862's that would annihilate a stock set of 243 heads that just about anyone could replicate with the same budget. Couldn't you mill the 243's down 0.030" and have a hair higher compression than the 862's with higher flow? |
I'd get the 243's and just mill them to get the same compression. |
Originally Posted by spent21
(Post 17809200)
So what would you do to a set of 862's to make them run? I had considered putting 2" valves in mine, but decided against it to keep my intake velocity up and not sacrifice my torque (5.3 truck). Couldn't you mill the 243's down 0.030" and have a hair higher compression than the 862's with higher flow? Stock 243 heads milled .030" would perform better than a stock 862 head, but not better than an 862 head like what I described. Just the valve job and blending will put the 862 head flowing better and making more power than a stock 243 head. Dropping the chambers down to about 56-57cc for a bump in compression will just be icing on the cake. |
stock 243s also aren't going to get you a ton of power either...15-20rwhp heads $350-450 milling $50+ (optional) gaskets $40+ (required) bolts $40+ (required) tune (required) plus add in labor or your time plus coolant, oil, and odds and ends if you put the cost of the 243s towards ported 243s used or cost to port the heads you have, you will be looking at an easy 40+ rwhp gain and only doing all the other parts/labor once IMO leave it alone or spend the money on heads that will REALLY make a difference otherwise you will be doing it again once you get bored with the extra 15-20 you get from stock milled 243s |
(Post 17809324)
I would put in 2.00" intake valves, valve job, blend in the bowls and chambers, and mill them about .030". For all that, those freshly machined heads would perform better than stock 243's for about the same price. 799 heads with 2.00" valves come stock on 4.8l and 5.3l engines, so I really don't think they'll hurt velocity or torque. Stock 243 heads milled .030" would perform better than a stock 862 head, but not better than an 862 head like what I described. Just the valve job and blending will put the 862 head flowing better and making more power than a stock 243 head. Dropping the chambers down to about 56-57cc for a bump in compression will just be icing on the cake. Who would you trust to do the 862 work? |
(Post 17803858)
Originally Posted by bww3588
(Post 17810107)
Those were 706's not 862's. |
OP, I have the 862 heads that were done by Texas Speed, and I am really impressed with how the car runs for such a budget head |
(Post 17810107)
(Post 17811225)
i thought both sets could be castechs as well |
| All times are GMT -5. The time now is 11:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
