LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Looking to run mid 11's? (https://ls1tech.com/forums/generation-iii-internal-engine/1703421-looking-run-mid-11s.html)
Mavn Jan 28, 2014 10:17 PM
Just picked up the following for my build. My goal is low-mid 11's and 430+ rwhp if possible. Not too worried about the horsepower since it'll be a stalled auto. What size cam? I was thinking a torquer v2 type cam. Lots of mid range power. Give me your suggestions!
799 heads. - going to get them milled and a valve job
Hd-2 shift kit
3200 Circle D pro series single disc converter
What's on the car now:
Long tubes
ORY
Cutout
Lid
Ls6 intake
thunderstruck507 Jan 29, 2014 08:59 AM
get the heads ported if you want to make your goal for sure, it's a lot of effort to swap heads just to put nearly stock ones back on...plus you will probably end up wanting more and pulling them to get ported later anyway, do it the first time and be done
sbf Jan 29, 2014 09:48 AM
What's the weight of the car
njmaster Jan 29, 2014 08:46 PM
Port the heads for sure. From what I've heard the torque v3 is an all around better cam than the v2. Why not get the v3 and step the stall up to a 3600? That should definitely get you well into the 11s.
HCI2000SS Jan 29, 2014 09:02 PM
I used to run the Torquer 2, and it had good all around power...especially in the mid range. If the car is full weight low to mid 11's are very doable, but you're gonna have to hook pretty hard to do that
1BAD98LS1 Jan 29, 2014 09:03 PM
I would start with a 4k+ convertor. With 799's you won't need a very large cam to see mid 11's. it's been done numerous times with just bolt-ons though..
garygnu Jan 29, 2014 09:08 PM
big stall and gears makes your goal alot easier .the torquer v3 makes a little more power ,but needs better springs .people have run 10s with unported heads .pick the parts you feel comfortable with ,and pick the cam last to best suite your total combo.
Mavn Jan 29, 2014 09:17 PM
I dd my car so I feel the 3400 stall is the perfect size. I'm just going to get the heads milled with a valve job for now.! And 3.73 gears soon too!!
td1168 Jan 29, 2014 09:35 PM
Realistically, with what you plan to do and no weight reduction high 11's might be a better goal to shoot for. That's with the car hooking up.
Mavn Jan 30, 2014 01:28 AM
High 11's would be great lol I'm down for that
thunderstruck507 Jan 30, 2014 09:12 AM
Don't know if you've ever had the heads off with the motor in the car but between the amount of work and pain in the ass involved and the cost of the milling, valve job, head bolts, head gaskets, and fluids it isn't even worth swapping them on unless you already have to pull them for some other reason.
sbf Jan 30, 2014 09:19 AM
Still haven't stated the weight but its plenty of cars on here that run those times and faster with a yanks ss3600 or circle d 3600c stall 3.73 or higher gear with vrx4,streetsweeper ht,eps 230/234.i think the best mods for these cars and price is stall and gears,I no of 3 on here that has bolt ons and a yank ss4000 running those times
(SS) Jan 30, 2014 09:34 AM
If i'm reading everything right you defiantly on the right track.I say send your 799 heads to AI to have them ported.You can consult with phil at AI or the cam guru martin at tick performance to spec you out a cam that will work with your heads and setup.Then you can look into a underdrive pulley,gears and tires.
Being your a automatic your 11.5 goal is really easy to get to.You have to be patient and pick the right parts the first time.
http://www.advancedinduction.com/LSX...cGMLS2Head.php
http://www.tickperformance.com/
01ssreda4 Jan 30, 2014 09:43 AM
Here's a similar build and how it reacted to some mods.....
https://ls1tech.com/forums/multimedi...pics-vids.html
Mavn Jan 30, 2014 10:13 AM
That dudes SS is sweet! Hopefully I can get my car to run that good!
01ssreda4 Jan 30, 2014 11:44 AM
Yeah he's alright, I've met him a time or two.
© 2026 MH Sub I, LLC dba Internet Brands
