rebuilt cammed with heads 5.3 first start up cam sensor codes help!
Old 02-01-2014, 07:00 PM
mrfubs's Avatar
Default rebuilt cammed with heads 5.3 first start up cam sensor codes help!
Alright so the good news is the engine runs So awesome and doesnt leak!
My question is im getting a cam posistion sensor out of range and circuit low. Every single sensor in the block is new, and i also never had a cam code previously to this engine swap.
Old 02-01-2014, 07:39 PM
Super Hulk Smash
JakeFusion's Avatar
Check your grounds.
Old 02-01-2014, 08:31 PM
mrfubs's Avatar
Originally Posted by JakeFusion™
Check your grounds.
Grounds are good i made note to them. 2 on LH side of block and 3 on the back
Old 02-01-2014, 08:32 PM
mrfubs's Avatar
I wonder if the cam and crank just need to be sync'd?
Old 02-01-2014, 08:36 PM
im-not-guilty's Avatar
What's the code # 341 342 343?????
Old 02-01-2014, 09:09 PM
mrfubs's Avatar
Man i dont remember my trucks at my shop, all i can tell you right now is that the information was CMP signal out of range and CMP circuit low voltage.
Old 02-01-2014, 09:25 PM
CattleAc's Avatar
Yes this would help...
Old 02-01-2014, 09:42 PM
mrfubs's Avatar
Alrighty. Im going back to the shop tommarow to finish it up and i will let you know what code numbers they where
Quick Reply: rebuilt cammed with heads 5.3 first start up cam sensor codes help!
