Best Street Oil Pan For 4th Gen F-Body ???
Guys,
What is the best "Street" oil pan for a 4th Gen F-Body with an LS stroker motor ?
I've heard a lot of complaints about the stock F-Body pan . . . What are my options, without getting into ground clearance problems. The car is not lowered and never will be.
Thanks !
Thanks !
The issues I have heard about say the pickup location causes problems and the sump not having enough capacity, especially if a high-volume oil pump is used.
LS1Tech Sponsor
However, Holley's newest pan should work: http://www.improvedracing.com/baffle...pan-p-443.html
That said, adding our oil pan baffle to the factory pan will solve those problems, but we don't really recommend using a high-volume oil pump.
"NOTE - Oil pan #302-2 may not be used with LS7 engines or "stroker" engines greater than 3.62".
I'm looking for increased capacity with ground clearance . . .
Thanks for the link, anyway !
