5.3 build crank wont rotate
I am stuck and so is my crankshaft. I have a 5.3 im building - cleaned and honed block, new cam bearings (installed by machine shop), new main and rod bearings (std size). Im re using the stock rods, pistons, and crank (all refreshed from machine shop).
Long story short- I was torqueing down the rod bearings and after final conclusion, if the #1 or #7 rod is torqued down the crank will not spin at all. Do I need undersize bearings? I took off the bearings multiple times and made sure it had plenty of assembly lube. Also when i took off the #7 rod bearing the upper had a pretty decent scratch out of nowhere?
I got .0015- .003
