very slow coolant leak from headbolt
I just finished building a lm7 bored over to ls1 with brand new PRC CNC ls6 heads I used factory mls head gaskets engine starts runs fine yesterday after fixing a small oil leak caused by a sensor I noticed coolant dripping on the floor from the far back passenger side headbolt these are brand new gm factory headbolts and reused and I did not put sealer on them cause I've never done that on LS engines before I don't think that coolant is going in the engine but I'm going to check today the block is 99lm7 block any suggestions?
Pulled heads inspected heads put new head gaskets new bolts even new dowel pins and thread sealer on bolts and retorqued engine runs great I figured what's in the hole will come out overtime and will seal its self I'll check it agian today
I thought maybe the gasket was out of line somehow the first time but I was extremely thero I know the bolts don't go into water jackets I put sealer on them just out of habit I'll see what she's doin today
Found the issue yesterday kinda dumb move on me the heads both have a hole for a ect sensor I had a older broken sensor thati used to plug the one hole and I guess I forgot to put a wrench on it all the way it was directly above the headbolt so it slowly leak around and dripped of the bottom typical but I'm glad it won't nothing big
