408, PRC 247, TSP giant cam, anybody run this?
Old 07-12-2014, 10:33 AM
VandykeT/A's Avatar
I ended up with the PRC 247 and TSP's 251/259 cam. Everythings set up to be at 11.5-11.6 compression.
Old 01-24-2015, 11:59 AM
yessir's Avatar
Any dyno results yet?
Old 01-24-2015, 12:51 PM
Rise of the Phoenix's Avatar
Should put down a good number with those heads and cam.
Old 01-24-2015, 02:19 PM
VandykeT/A's Avatar
The car made 523/487. When it was put together the car actually had a strange noise we couldn't figure out. After the fact I had the intake off fixing a vacuum leak the car had from the beginning and noticed half inch or rocker bolt in the port so while cutting those off one day I found the noise. I could pick several of the rockers off the valve tip over .0020 and one I could bottom the lifter out but picking up on the rocker. With those issues fixed it probably would have made a little more power. That explains the minor spike and nose dive on the dyno graph.
Old 11-18-2015, 10:45 AM
ds98formula's Avatar
Dang good numbers. Do you happen to have the graph?
You plan on fixing the issues and rerunning it?
Old 11-18-2015, 04:59 PM
VandykeT/A's Avatar
That was after getting everything fixed and changing exhaust. Different tuner and he loaded the dyno. He also removed the air box lid and power went from 555 to 571.
Old 11-18-2015, 10:20 PM
Super Hulk Smash
JakeFusion's Avatar
Those PRC 247 heads are no joke. I'd like to see what it made on the original dyno - hard to compare between the two.
Old 11-18-2015, 10:49 PM
VandykeT/A's Avatar
I don't have the original sheet but it made 523/487. The original tuner was a joke. I was getting 10.0 afr at part throttle. Car wouldn't run at all cold constant 10 afrs. Wot would mellow to 12.6 up top on my wideband this tune goes between 12.9-13.1 the new tuner had 3 degrees more timing in a lot of areas to. I didn't understand the loading the dyno deal but if the car made 535 and loading the dyno kicked it to 555 then removing the air box lid took it to 571 on the unloaded dyno the car would have to be in the upper 540s 550. I just don't know how loading the dyno effected the numbers. I've never seen a 408 make 571.
Old 11-20-2015, 09:12 PM
Nice results. How hard does the tq come in? Does it drive nice
Old 11-21-2015, 12:35 AM
VandykeT/A's Avatar
Torque is good all the way through. A 4k hit in 2nd gear seems to be it's wheel house. It's pretty brutal. And driveability is actually really good. Very very Minor bucking at light throttle occasionally but never really anything annoying. It's actually been my dd for the past month pretty much. I drove it 3 hours to the track one way when it ran the 10.55.
Old 11-21-2015, 12:43 AM
Tuskyz28's Avatar
The fact you drove the car 3 hours away and went a 10.55 is what I respect! No trailer queen!
Old 11-21-2015, 01:43 AM
  #32
VandykeT/A's Avatar
I just hate switching tires back and forth at the track and having to worry about getting my street wheels stolen while I'm racing lol.
Old 11-23-2015, 10:50 AM
  #33
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Great results buddy! Send a pic of the car & a copy of the dyno sheet & I'll add it to our web site!!
The PRC 247s know how to fly don't they??
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-23-2015, 12:27 PM
  #34
VandykeT/A's Avatar
Will do. If I can get to a track with a better da than 2k, enough gear, and traction. I think I can be knocking on 9s door na with a stick.
Old 11-24-2015, 11:17 AM
  #35
I agree with Matt @ Tick as long as the octane of the gas doesn't drop with altitude. In Lubbock we were at nearly 4,000ft and the highest octane you could buy was 91
__________________
Jason
2005 Twin Turbo C6
Old 12-04-2015, 08:34 AM
  #36
VandykeT/A's Avatar
Didn't have any good pictures of the car but here's one.
Old 12-04-2015, 08:36 AM
  #37
VandykeT/A's Avatar
Quick Reply: 408, PRC 247, TSP giant cam, anybody run this?
