Ls7 lifters
Old Jun 13, 2014 | 09:48 AM
diablo-Z's Avatar
Default Ls7 lifters
What's the difference between the gm performance ls7 lifters and the Delphi ls7 lifters ? There prices are different gm performance is a bit more but just wna the difference between them two
Old Jun 13, 2014 | 10:22 AM
squalor's Avatar
I saw the price difference on Brian Tooley's site and also want to know the difference.
Old Jun 13, 2014 | 10:26 AM
Havoc40's Avatar
Nothing different. The GM Performance lifters might come from a different manufacture. That being the case, they'll still have the same performance and identical set-ups.
Old Jun 13, 2014 | 12:53 PM
Brian Tooley Racing's Avatar
Both are made by Delphi, and when you disassemble both for inspection they look identical. However they carry a different part number from GM so I'm not sure.
Many other shops sell the Delphi lifters as genuine LS7 lifters.
Old Jun 13, 2014 | 03:05 PM
diablo-Z's Avatar
So both perform the same I guess Delphi it is...would it matter what trays to run like ls2 ls3 ls7 etc will work?
Old Jun 13, 2014 | 03:27 PM
ls1 1990 VN's Avatar
Just use the LS2 trays, they also allow oil to drain back better
Old Jun 13, 2014 | 04:36 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
I still have my ls1 trays in using ls7 lifters
Old Jun 13, 2014 | 07:26 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Definitely get the LS2 trays. They're much more robust
Old Jun 13, 2014 | 09:46 PM
crainholio's Avatar
Like he said, substantial design improvement. Or go with link-bar lifters and chuck the trays.
Old Jun 13, 2014 | 10:23 PM
diablo-Z's Avatar
Delphi ls7 lifters and ls2 trays it is..... Also Would I have to soak the lifters or I can just install them
Old Jun 13, 2014 | 10:39 PM
slowsol95's Avatar
You need to soak the lifters in oil before you install them
Old Jun 14, 2014 | 10:28 AM
diablo-Z's Avatar
For how long do they need to be soaked for? I can use any kind of oil?
I ordered my lifters and trays already from BTR
Old Jun 14, 2014 | 02:01 PM
Over night & your usual engine oil
Old Jun 15, 2014 | 12:36 PM
diablo-Z's Avatar
Ok thanks a lot fellas for the info
Old Jun 15, 2014 | 01:09 PM
crainholio's Avatar
I wipe down the external surfaces w/ mineral spirits and a clean cloth, including the roller, then soak in whatever 5W-30 is on the shelf. Light smear of assembly lube on both ends of the pushrod during final assembly and off you go.
PS: be sure to measure for pushrod length before final assembly, get the right pushrods for your setup.
