Oil In Intake - LQ4 - See Pics
I just started to pull some of my LQ4 down to prep for the cam swap. When I pulled the intake off, I noticed oil on the gaskets and head. You can also see that it has had oil in the intake and the intake ports on the head for a long time. Is this normal for a LQ4; or is this thing burning oil?
So run the PCV hose to the catch can; then a hose from the catch can to the intake?
I have seen catch cans with two inlets; should I go ahead and run the other hose to it as well, or just leave it alone?
