Biggest cam with LS6 Springs & Stock Rockers (4.8 or 5.3) ?
Looking for some suggestions for a biggest cam with LS6 springs and stock rockers in either a 4.8 (2002) or 5.3 (2001) since I have both! This would be with 4L65e trans with Trailblazer Torque Converter and either 3.73 or 4.10 rear end.
Is there a off-the-shelf cam that would work or I need to get a custom cam (not concerned about mpg or emission) ?
I am sure Comp Cam could hook me up with something but looking for some suggestion here. I was thinking about getting Z06 cam ($280) to save little bit and LS6 springs ($60). Used Z06 cams are even cheaper on eBay. However, I was informed by mrvedit that factory camshaft are "grocery getter". Even the most aggressive has less than 0 degrees overlap at 0.050. This is necessary to meet mileage and EPA requirements. I need to aim for between 0 and 3 degrees overlap at .050. The LS6 cam is NEGATIVE 12 degrees overlap which is a "grocery getter". I need to get a cam with 0 to 3 degrees of overlap, which is much higher than any GM part number and it almost demands a stall with 3000+ rpm or else the engine will bog at low rpm and therefore Trailblazer Torque Converter may not work.
Chevrolet Performance Valve Springs 12499224
http://www.summitracing.com/parts/nal-12499224
Chevrolet Performance LS6 Corvette Camshafts 12565308
http://www.summitracing.com/parts/na...WaAaAtOR8P8HAQ
Thanks
Waid
Thanks
Waid
Moderator
Glad you are posting because members here know a lot more about cams, valvetrains and specific parts than me.
First you need to specify exactly what your goals and preferences are.
I understood them as the beginning of a limited budget mostly-track car.
Most suggestion of a cam with 0-3 degrees overlap is very, very modest as many mostly-track cars are in the 12-16 degree range, but this always requires a complete upgraded valvetrain.
You should also read the many cam related threads here so that you don't ask the same questions for the 100'th time.
Start by giving us you current goals, future plans, preferences and perhaps a budget and I am confident you will get good advice here.
Did you look at the gm asa or hot other gm hot cams?
maybe something in the 224 range might get you where you want to be but I'd step up on the valve springs to something like the PAC or comp 918 beehive springs for piece of mindm
^^^Agreed. Though for the price of a new PAC or Comp beehives I would rather go with BTR Duals.....thats just me. Not a huge price difference and I have been a fan of BTR due to the quality of springs. Lunati has a nice Dual Spring Kit for a similar budget.
Moderator
The ASA cam for LS3 has a whopping 11 degrees of overlap, but only .525 lift which sounds like a cam with relatively gentle slopes that will work fine with single/beehive valve springs.
The hot cam has 0 degrees of overlap and also .525 lift and is therefore much milder and might still work with a stock converter.
Here some good thread comparing them:
https://ls1tech.com/forums/generatio...m-hot-cam.html
http://www.corvetteforum.com/forums/...gt2-3-cam.html
Look at either the BTR or cam motion "drop in" truck cams. Anything bigger will likely require more converter to see any real benefit. What does a Trailblazer torque converter flash to maybe the Hot cam would work but it still wouldn't be optimal.
Thanks
http://www.briantooleyracing.com/btr...-camshaft.html
Our Truck cams were designed with low lift so GM LS2, LS3 and LS6 springs and pushrods can be used, making these the most affordable truck cams available.
The Stg III cam has a noticable cam sound that so many are looking for. It will make even more average torque than the Stg II cam, at the sacrifice of some low end torque and fuel mileage.
BTR TRUCK STAGE III CAMSHAFTThe Stg III cam has a noticable cam sound that so many are looking for. It will make even more average torque than the Stg II cam, at the sacrifice of some low end torque and fuel mileage.
Duration at 050 inch Lift:218 int./224 exh.
Valve Lift with Factory Rocker Arm Ratio:0.553 int./0.553 exh.
Lobe Separation (degrees):113+3
Duration at 050 inch Lift:204 int./218 exh.
Valve Lift with Factory Rocker Arm Ratio:0.550 int./0.550 exh.
Lobe Separation (degrees):117.5
Chevrolet Performance Gen 3 Hot Cam Kits 12480033
Duration at 050 inch Lift:219 int./228 exh.
Valve Lift with Factory Rocker Arm Ratio:0.525 int./0.525 exh
Lobe Separation (degrees):112
The BTR TRUCK STAGE III CAMSHAFT shoulds really good!
LS1Tech Premium Sponsor
We have a few different truck cams that have made good power with great driveability on a stock converter. Including those that do great with ls6 springs.
Give us a call, we can definitely help you get what you are looking for. If our off the shelf cams are exactly what you need, we can do a custom grind.
Right now we have all our cams on sale for 350.00...
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
1995 Mustang GT with 3.27 rear end, 4L65e and will use Trailblazer Torque Converter. May get 3.73 or even 4.10 for the rear end. I want to keep it streetable and take it to the track on weekends.
What specific Texas Speed Cam do you recommend with LS6 springs?
Based on my car project description and combo, what motor (and cam) would you use. The 4.8 or 5.3 (I have both)?
I am trying to keep the cost down since my Falcon project is draining me really bad!
Thanks
For an off the shelf cam that will work with ls6 springs I would run the comp 212/218 .522/.529 114lsa or the ls1 hot cam 219/228 .525/.525 112 LSA. Id personally use the hot cam and the 5.3. I didn't catch exactly what your plans are unless I missed it somewhere, but we could always do something like a low lift 220/224.
__________________
I use a the Howards gm asa cam w/ ls6 springs. Still using the stock rockers and push rods. I was on a budget at the time as well but will be swapping out the springs and push rods within the next 6 months to avoid any issues but so far i have no issues.
I am finishing up my 1964 Falcon project but I always wanted something more for the drag strip - nothing to crazy and keep it low budget and build with with my two young boys. I am looking to put the motor in a 1995 Mustang which has a 8.8 rear end with a 3.27 gears. I am leaning toward putting in the 4.8 to abuse around at the track and keep the 5.3 for future project. Even if I don't ever use the 5.3, it is more in demand and will be easy to get my money back.
Waid
