Front 4 outter head bolts spewed seltzer water at me??
So, I was pulling my heads off the mockup engine. When I cracked the 4 outer large head bolts, everything was fine. When I got to about 1-3 threads loose, liquid spewed out like it was a rabid alkaseltzer dispenser. I thought is was antifreeze (it has to be) but it was clear, not orange like the water in the jacket that dripped all down my sleeve earlier.
I will assume water made it past the headgasket into the bolt holes or we talking about a porous/cracked block/bolt holes? I dont think it could be cracked or the pressure should have released by now?
Sounds like bolt holes weren't dried out prior to installing head bolts during the previous head install (not original dry install, but head re-installed after having had removed them w/ coolant in block). If water isn't removed from the head bolt holes before installing bolts, it gets trapped in the hole by the bolt & can expand & crack block &/or remain pressurized until bolts are removed.
Block was sitting out striped for the most part for a few months when I grabbed it off the recyclers floor
Yea, it idid!! Came out under high pressure with a "pshhhhh" sound and pure foam. When it settle down, rather quick, it was a clear liquid. Wasnt green-ish or orange-ish (that I remember), like what was actually still in the block that dripped all over me when I removed the first head and turned the engine, but clear. I did work on it at night with dim-ish light while it dripped on a dirty block, so, maybe I didnt see it well enough? Still looked darn clear to me cause it did puddle up fairly well in one section. Thats my story and I am sticking to it, lol. Well, at least being pressurized means it didn't crack anything??? Gonna go out in a few days to see if there is any left in the bolt holes to get a better idea.
Guess that means its a sadistic POS!!
Thanks for the input guys
