What do you think of this cam choice
I have been reading for a few months now to try and work out what I need to get to where I want to be
so about my starting point
99 ls1 camaro auto 4 160k miles runs very well was dyno'd just before I bought it and it was making 286 rwhp which I believe is spot on
the only mods so far are smooth intake pipe and air box mods Inc a lid
the dyno was before this
Where I want to be
A fast fun street car I will only do 2-3k miles a year and maybe make it to the track once or twice it won't be a daily driver but I want decent street manners I am UK based and ls parts are harder come by and I have import duty and vat to pay on any imported parts and international shipping is getting more expensive
I have but not yet installed an ls6 intake and some speed engineering long tube headers
I plan on diy porting my stock heads and maybe get them milled 20 thou to up compression and I was all set for a tsp224 cam and supporting bits with pac behives but I have come across some Howard's cams one a 224 224 .612 with 13 degree lsa and then a 226 226 .525 with 13 degree lsa
I am thinking of going 3200 or 3600 stall when I do my mods
So what are people's thoughts on the Howard cams any good? They are quite a bit cheaper and can be bought as a kit that is very competative Or should I go tried and tested tsp and spend a bit more
There are cases where a single pattern cam might be good but a normal NA setup isn't that case.
Further more a set of inexpensive PAC1218 valve springs would work great with that cam. If you don't mind the more aggressive lobe then there's nothing wrong with getting a Howards cam, like the 190375-12 or one of the few they offer with fairly mild lobes like the 190325-12, or 190325-15 that Howards offers.
http://www.ws6project.com/user_stor/...e-rpm-224-228/
http://www.ws6project.com/user_stor/...valve-springs/
What are the benefits of the split duration cams I read so much in favour of tr224 tsp224 and 228 a friend has the 228 and loves it
I don't want to spin the 160k miles bottom end up to 7000 so if it drops off early that will be no bad thing
And yes I am aiming for power under the curve as such it's not a weekend race car and I need to enjoy driving it when I am not getting on it as well
I will have to make a choice and hope I have made the right 1
http://www.texas-speed.com/p-1146-te...-camshaft.aspx
http://www.briantooleyracing.com/chevrolet.html
Thanks
Dominic
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
