Ordered Mast Small Bore LS3's
#83
It will be rifle drilled to reduce its rotational weight by 2.x pounds.
It will have some silly camshaft sensor stuff near the rear bearing journal.
Most likely sixteen shiny bumps will open/close 8 intake valves and 8 exhaust valves.
This just in........the PAC valve springs will not be happy with the shapes of those bumps....
#84
Nothing more than "I'll be surprised by the specs". It's going to be a while before its together. There's a LOT of piecing together i need to do, as well as waiting on results of new manifolds...
There you go again revealing secrets...
It will be rifle drilled to reduce its rotational weight by 2.x pounds. It will have some silly camshaft sensor stuff near the rear bearing journal. Most likely sixteen shiny bumps will open/close 8 intake valves and 8 exhaust valves. This just in........the PAC valve springs will not be happy with the shapes of those bumps....
#87
I know, sucks they're advertised as taking ls valvetrain but that's not the case. I also talked to ed but need to be ready with some $. Xceldyne sells retainers for psi 1512's that are within .010 tolerance wise of btr retainers but they run $27 a piece. The k motions I have would work but the open pressures seem high and don't wanna jack up my valves.
#88
#91
I contacted AI with possibility of small boring a set of LSA heads but if that is not an option I will be also purchasing a set of these heads for a 347 boost setup. Will have to contact ed about valvetrain setup and I will be running a BER ported ls3 intake since ber is right down the road from my house
#92
