head gasket thickness???
Not sure..... but a LS9 gasket would be the ticket.
Might have to give cometic a call.......
How can you possibly know the compression of the motor when you don't know what head gaskets you're using. Also those pistons must have a seriously large dish in the 18-20cc range if your compression is anywhere near 9:1 with 243 heads.
I know around what it's going to be. And with a stock gasket that's almost exactly what it will be that's why I want to go thinner to bring a little bit of compression back. I know it want be much but every little bit counts
