boring a good 5.3 to a 5.7 - worth it?
I have a iron 5.3 and the legendary infamous LS1 5.7 status symbol keeps luring me to the dark side. I want a 5.7 to say I have a LS1 but the bores look really good, albeit a little rust around one of the top of the cylinders that should clean up with a hone.
So, I know the 5.3's make decent power, but, since it is a used engine, is it worth spending the money for new pistons and getting it bored?
Moderator
Received 1,835 Likes
What heads? If you're going to do some porting work or move to 243/799's or both, the extra bore will make a very big difference. If you're keeping the stock 706's, they don't flow very good, but your compression would increase some. After boring it out, you'd be able to run a bigger cam, larger intake, more mods, more mods, and next thing you know, you wake up in a ditch with an eye patch.
Overall, I'd say yes, it's worth doing. If you have plans for future mods, you'll be in better shape to take advantage of them.
Moderator
That's funny. I was just checking on this thread, because I had thought - "Why not just pick up a LS1 short block, save some work, AND get a 5.7L?"
Oh, and I have already ended up in the ditches a few time but seemed to have avoided the eye patch's
Right now, I am just wondering about the iron block. Some say to bore it to a 6.0, but, would be nice to be able to rebuild it twice if needed and not gouge it out all at once. Then again, I dont think I can go past 5.7 because it is not a 5.3/5.7/6.0 block. But hey, sometimes you gotta do what you gotta do.
Moderator
I'll give you a theory on the 6.0, and you tell me what you think. There is nothing magic about iron vs aluminum. The iron block weighs more, but not 10 mpg worth more, right?
So, here is a quick thought experiment... LS2 vs LQ4. I had a LS2 get me almost 30mpg highway in a manny tranny corvette. 22 around town. The LQ4 gets like 12 mpg, 14-16 on the highway. The LS2 has 64cc chambered 243 heads and consequently very high compression. Compression = efficiency. The LQ4 has 317 heats with 74cc chambers and consequently lower compression = lower efficiency. Now, look at the LS3 that is a 6.2 L with an even bigger bore and gets decent mileage in a Camaro.
So, in my orange truck below, I mated an LQ4 block to a set of 243 heads and a LS2 cam, intake, and shorty headers. Effectively making it an iron LS2. No DOD, not VVT. Nothing crazy, right? Gets 22mpg mixed highway and city. 19 city only. 25 cruising. Now, it is an S10, so it weighs less than my dog, but I do think that getting the compression up in the mid tens and giving it an LS2 top end contributed to the mpg as well.
All that to say the 6.0 isn't bad from being a 6.0. I suspect it was inefficient due to lower compression - maybe GM did it to help it run cooler, I don't know.
If it's me, I'd put the bigger motor in the truck if I was using the truck for towing and hauling. Basically, whichever vehicle I planned to use for showing off would get the better motor
Moderator
now my showoff car is the TA. my next plan rhymes with "408". maybe you can figure out what I'm going to do next from that clue...
What do I think, hmmmm....
I wanted to get a new blazer and ditch the cherokee since they have drop in parts for a 6.0. Upon researching, blazers have a full frame. Comparing the curb weights, the blazer is 600lbs more than the cherokee. I could only assume the corvette is lighter than the cherokee, so, we will add 200lbs to that. Now, being that the s10 has a full frame like its big brothers, your pushing around an extra 800lbs give or take if you just ate a big burrito sandwich or not. As a final note, the aluminum is 80+ lbs lighter, so, add that in also. Not much more to make it a special block over the steel, but, it is extra weight none the less. Now, to save gas money, is it worth $1k (price of a summit/GM block) to save fuel? Probably not, but, if I am going to put it inot my car, then, maybe. Truck not so much. All that could count for a good 5mpg diff.
Now we get into the speculation part. I really wish someone would (since people just like to experiment anyways) take a 5.7 and a 6.0 and compare them. starting with a block only, set one up with internal goodies, run it and swap ALL the internals out (except for balancing) and put it into another. That includes making sure the pistons weigh the same. They share the same stroke, so, all timing, cam and sensor positions will remain the same. The "only" thing that has changed is the bore size. Now, run that on the street doe 20k miles and compare the results.
They are close, so, no computer tuning would be needed if you use the same injectors. Were not talking about racing here, so, I dont think anything bigger than stock 5.7 is needed, and, if so, just go one size higher.
Next would be the computer. Again, all perams could be the same. Since it is a MAF setup, the MAF will tell the computer how much it is breathing. Tables can stay the same because they are only used for open loop tuning for the most part.
Other than the above, engine to engine comparison is nothing more than speculation of common sense, but, no proven facts, just a lot of sht talking. Sure, one can never know with separate computer, different heads, diff cams... Would be logically impossible to compare. If it walks like a duck and talks like a duck, locical common sense would say it is a duck, or, in this case a 6.0 uses more gas than a 5.7, but, and here is the big "but" (and not my ex gf's big butt) .......... Everyone I have talked to that has a 6.0 in a truck or car says "she is fast but uses gas!
With out actual comparisons, makes me say really? Why? Why is everyone having such a gas crises with these things, lol???
Moderator
LQ4 = 9.5:1
LS2 = 10.9:1
I'm guessing GM decompressed the LQ4 to help it run cooler for towing, but that is a complete wild guess.
Doing what? A 5.3 to a 5.7? Cause I have a 5.3 block and set of 5.7 forged pistons and rods that I'm thinking about doing this to also. Unless it's a 4.8, an LS7 or a stroker, the cranks are all the same. Putting twins on mine.
I had thought someone would say that when I posted. I agree, it isn't a perfect comparison, but I don't think it's true that a LQ4 would get the same MPG in a vette as an LS2, because the compression is lower in the truck engine. Compression is efficiency.
LQ4 = 9.5:1
LS2 = 10.9:1
LQ4 = 9.5:1
LS2 = 10.9:1
However, I think the most important reason why compression is lower in the LQ4 is to allow it to run on 87 octane regular fuel. Remember that this is a truck engine. And trucks are, of course, frequently used for commercial purposes. Generally speaking, if you are using a truck to make money, you want to minimize fuel costs. I’m guessing that, cost-wise, the increased fuel consumption due to efficiency loss from lower compression is outweighed by the lower cost of regular vs premium gas (which the LS2 requires). I’m also guessing that having knock sensor retard on a high compression engine when it runs low octane fuel would decrease efficiency FAR more than just running lower compression.
Also remember that, if the truck engine required premium, this would be a ‘strike’ against trucks so equipped. This would most certainly be exploited by the competiton (ie Ford, Chrysler, Toyota, and Nissan) to gain market share. High performance ‘sport model’ trucks geared more toward non-commercial use may be an exception. But the ‘run of the mill’ 6.0 needs to run regular in order to be a viable work truck.
