20ftlb loss after TV2 in lq9??
2006 GMC Sierra with an 05 lq9. Truck had longtubes, 3200 stall, airaid MIT and KN drop in. Before cam my numbers were 343hp/375rwtq. Switched the stock can for a tsp tv2 and single beehives. Truck was retuned and lost 20rwtq at peak making 373rwhp/353tq. Truck feels really strong though. I realize that number are just numbers, but this is the same dyno and tuner. I didn't think I would lose 20ftlbs over all. Going to track it soon and see what it does down the 1/4. But is this common with this cam?
^^ agreed. Low end yes, but not at peak. You have some other variable going on. That cam has been a proven performer for many years. A few things I'd check off the top of my head is pushrod length (use a checker tool), if it's too long it could be holding the valve slightly open. Check timing (tune). Double check to make sure it wasn't installed a tooth off on the timing chain, & check all of your plugs etc. Either there's a change in the dyno from your previous pull to now such as weather conditions, calibration & so on or something else is going on for it to lose torque at peak. All I can say is start checking.
Well the truck runs good, and pulls much harder through the rpm range IMO. The pushrods are 7.400 but I will double check to make sure they are closing all the way. Wouldn't that cause the truck to run very poorly though? I think as long as I pick up a few mph at the track I can chock it up to an inconsistent dyno.
If your valves arent closing your motor will not run because you will bleed off too much compression. As for the torque loss, it doesnt surprise me, though its a highly favored cam around here the v2 has never impressed me, and I also know the v3 was created to combat the lackluster bottom end the v2 has. I think there are lots better choices.
No way a cam like that will lose torque throughout the range.
Although I do question the initial numbers more so than the end result. 375rwtq from a bolt-on LQ9 through a stalled auto seems a bit generous. Was the 2nd run done on the same dyno?
And numbers are just numbers, I would put more weight on how the car runs now vs. pre-cam. Have you ever taken it to a track (assuming not since this is a truck)?
Yeah I'm coming to the conclusion that the dyno was way high before. I did track the truck before cam, and went 13.4 @ 101 w/ 1.91 60ft. Track times will tell me the truth.
