Lifter Shootout which lifter and why? Everyone's opinions welcome
#43
I have read posts withing the last couple years stating the 5315 was good to 7200rpm, then seen the same vendor 6 months later say 6500rpm. Trust me when I say I have done a lot of research and it still apparently was not enough.
#44
I did not mean you specifically, just referring to different vendors. I did not know you were a Morel rep until recently. I appreciate your info you have given, but it is just the opposite of what I have read and been told from a few other vendors. Now that this information is out there, I suspect the advice given will change by those few.
I also know for a fact that Morel has been contacted for direct accounts and everyone has been told....At this time we are taking on new accounts because we can't supply our current customers. For some this did not sit well.
My advice, you want the biggest wheel on the lifter you can get.
#46
So what did we decide? LOL
Im building an LSX and while I have never had any problems with LS7 lifters I'd like to move to a link bar even though I don't need to as the LSX has trays. Application is a twin turbo @ ~1000 RWHP. All Pro heads with ~150# seat pressure, J2k rockers, 3/8 thick wall pushrods and nothing crazy for a cam (231/236 .617 .623 on 118+2) although I don't know the profile. So the rest of the valvetrain is set. But opinions on link bar lifters seem to be like ******** which is why I like this thread.
#48
Heres the thing, I dont care if they revised the 5290 or not the failures I saw left a bad taste in my mouth and I would not want to be the next guinea pig even though i am sure they are fine now. With the weight of the J2K's I would seriously consider a link bar. If you really didnt want a link bar then the 2110r is the next best drop in option since it has .150 travel like the 5290 does.
As far as quality link bars go theres the 5206/5274 and 5294. The 5206 is comparable to the 2116 johnsons and the 5294 is comparable to the 2126. The difference is the johnsons are about 100 bucks cheaper than the morels. Here you cant make a bad decision all are good. Comes down to personal preference. The short travel versions might be better for your build with the boost, just something to consider.
I could not get in contact with anyone at morel, even on their website it says they do not take calls from normal customers, that kind of rubbed me wrong. I realize I may not be a dealer but if I'm dumping 600 into a set of lifters and I want to talk to the company who made them for a specific reason then hell ya I should be able to. OTOH I pmed Havoc on here who is Randy the chief engineer at Johnson, he asked me to call since it would be easier. Not only did Randy spend 30 min on the phone going over my options and my build with me but he asked me to follow up with him on my choice and I even called him back a few times with questions, all of which he was polite and happy to answer. That did it for me, I dont care how big of a company or how small you are customer service is key.
Honestly that doesnt really impress me all too much. They arent using the 5315 in Nascar. They are using lifters that cost 4 times more than what that costs hell probably even more than that. Morel makes HQ lifters like everyone else but the 5315 is not meant to be that. Johnson 2110's go in the copos that live 1/4 mile at a time and go to 8500 rpm as well so they both have good options.....
#49
The copo deal is really what has my eyes on the 2110s, if gm hand picked them when they could've had any lifter they wanted then it's probably a pretty good choice. Of course I'd like a lifter with a bigger wheel and link bars but at what cost, not worth it imo.
#50
This site cracks me up...I spent a bunch of time doing research before I bought my lifters and everybody said the 5315 is a much better lifter then the LS7. Especially the units from 2014 on that have the revised design. Now all of a sudden it is sub par to the LS7 in 2 months time lmao. You can look at the LS7 and the current 5315 and easily tell which one is superior. Btw I spoke with those names you mention and the only one that did not recommend the 5315 was Tony.
I can see the 5315 not being advised for your setup with the spring pressure and rockers you are running. Again why are you overhauling the valvetrain? Did you change cams or been dealing with valve float issues?
Btw I appreciate you putting this info out here. I am just a little annoyed that many recommended the 5315 for my setup and now I am reading this lifter is sub par to a LS7. Does not make me very happy. I would of went with the 2110 Johnson had is been brought to my attention. I just did not see the need to spend 650.00 on a short travel. Hell I would go tight lash solid roller before I did that.
#52
You can't compare a .700" wheel lifter to a .750" wheel lifter. The boys as PAC decided to handle lifters. They bought everyone's lifter and took them apart to decide what they wanted to sell.
When you compare lifters you compare a .700 wheel to a .700" wheel. When you step up to a 5206 your getting a whole new level of lifter with tool steel components. Morel leak test every single lifter...everyone. That is quality control.
#54
So a pushrod that tapers from 3/8" to 7/16" and back to 3/8" is stronger than a full length 7/16" pushrod of the exact same wall thickness and material? Can you show me the data?
#55
It was never any contest that the .750 lifters are better than the .700 ones, so I'm not sure what the point is here? Thats pretty much common knowledge, and the price point of all the models reflect that.
Hera are some other tests done by vettenuts. The only way to get a tapered pushrod stiffer than a full dia one is to increase wall thickness. But that is an entirely different variable. Only changing the diameter on a pushrod, leaving thickness alone will result in a stiffer pushrod for the full dia length one.
http://www.corvetteforum.com/forums/...stiffness.html
#57
http://www.yellowbullet.com/forum/sh...shrod+diameter
#58
A tapered pushrod will create stress risers in the tapered areas. As you apply a vertical load the forces will be concentrated on the end because Pressure=F/A so as area (diameter) decreases you get more pressure on that piece which will cause the pushrod to buckle somewhere along the taper. This is also the main reason diameter plays a much larger role in stiffness over wall thickness. The surface area you gain with a .135 wall to a .080 wall is tony compared to just increasing overall dia...
On a side note I just picked up a set of arp head studs torqued down 1 time for mock up for 175 bucks no more shitty TTY bolts for me lol. Those things scared the **** out of me every time I torqued a set.
#60
lol thats one of going to respectfully disagree on. I've never heard of problems with studs really. I have had water in the bolt holes though multiple times when putting heads back on even after cleaning the hell out of the block. With studs at least I can monitor how they are going in and instead of torquing them down they just go in hand snug so much less chance of screwing something up lol
