400+ CID with 243's?
Old Aug 15, 2015 | 12:46 AM
JWStevens's Avatar
Default 400+ CID with 243's?
I'm considering buying a 400+ inch short block but I've got a nice set of ported 243's. Has anybody done this and had good results? Its my daily but I still want it to be fast.
Old Aug 15, 2015 | 01:38 AM
kinglt-1's Avatar
Yes there are a few threads in the dyno section of 418" strokers making 550whp with a quality 243 head and fast intake.
Old Aug 15, 2015 | 07:59 AM
01ssreda4's Avatar
Yep, I believe it can be done successfully. It may not be 100% optimal for an all out NA engine but should be a very nice driver.
Old Aug 15, 2015 | 08:32 AM
HCI2000SS's Avatar
If it's truly your "daily driver" I'd by a beater first lol
Old Aug 15, 2015 | 10:24 AM
JakeFusion's Avatar
Super Hulk Smash
The TEA Stage 3s made 600rwhp back in 2005 on a 440.
They are lousy heads, obviously.
Old Aug 15, 2015 | 10:51 AM
redtan's Avatar
Ported nicely and big enough valve they can be made to flow 330+ cfm which is going to be pretty good even for a 402 size stroker. Velocity might suffer down low, but with a stroker and decent compression you'll make plenty of torque down low to make up for that.
Old Aug 16, 2015 | 08:05 AM
sbf's Avatar
sbf
like stated above its a few have used the 243 heads and made alot of power i plan on using my tea 243s on a 418
Old Aug 16, 2015 | 11:30 AM
Jimbo1367's Avatar
I never knew TEA had a stg III 243s. What does this consist of?
Old Aug 16, 2015 | 12:30 PM
redtan's Avatar
Think they just have bigger valves, 2.08 and 1.60. The porting is usually the same.
Old Aug 16, 2015 | 12:36 PM
SS69LS1's Avatar
I'm running texas speed 243s w bigger valves on a 402, 11.5 comp, fast 102, 235/242 111 and it made 537 to tires.
Old Aug 16, 2015 | 12:38 PM
redgto4u's Avatar
I'm running ai 243 heads on my 418. They perform very well imo. Sure I could of put some really nice afr 245's or even a set of ls3 heads on it. I had these heads already and had to stop somewhere!
Old Aug 16, 2015 | 05:35 PM
01ssreda4's Avatar
No ****. Budgets get blown out of the water just trying to make a quick and fun street car.
Old Aug 20, 2015 | 10:05 PM
JWStevens's Avatar
Yeah, its really my daily. I've got a truck though. That's what I needed to know guys. Thanks a lot for the feedback!
