Critique My setup And Let's Get it built So i Just recently Purchased a 2000 A4 Trans am looking to get back into the hobby .So i have been Reading and talked to martin at Tick a few times about a setup .So i have finally put together a build But i would like some Insight and opinions from you guys that have far more Knowledge than I .So here we go.It is a daily driver Full weight car but i am looking to get the most out of it can .So here is my setup i put together.later on i will be doing a 4l80e and 9 inch and maybe Small shot 100 Undecided on Heads(What you do guy's Think) No flycutting Fast 92/92 SNS Stage 2 LS2 camshaft 231/235 .617/.621 111+2 ported ls6 oil pump 1 3/4 Texas speed headers Under drive pullys 2.5 inch X pipe 3.73 gears trans cooler 3800 Fti Stall sub frame connectors |
How much you willing to spend on heads? |
Id go with TSP 1 7/8 headers and 3 in duals instead. And id rather go with a 4000 stall. As for heads id probably look into some LS6 heads.. look into TEA... or livernois and WCCH.. |
Originally Posted by ls1chris
(Post 18942487)
So i Just recently Purchased a 2000 A4 Trans am looking to get back into the hobby .So i have been Reading and talked to martin at Tick a few times about a setup .So i have finally put together a build But i would like some Insight and opinions from you guys that have far more Knowledge than I .So here we go.It is a daily driver Full weight car but i am looking to get the most out of it can .So here is my setup i put together.later on i will be doing a 4l80e and 9 inch and maybe Small shot 100 Undecided on Heads(What you do guy's Think) No flycutting Fast 92/92 SNS Stage 2 LS2 camshaft 231/235 .617/.621 111+2 ported ls6 oil pump 1 3/4 Texas speed headers Under drive pullys 2.5 inch X pipe 3.73 gears trans cooler 3800 Fti Stall sub frame connectors Is it still LS1? That drive line is going to suck up some power vs a stock set up so you will need to make more power to offset the difference. The 1-3/4" header will be fine on a LS1 car with single 3" Ideally a 1-3/4"-1/7/8" step would be the way to go. If a larger short block is in the future go with the 1-7/8" Our stage 2 heads will be fine on a LS1 with that small shot of N2o. If your thinking about more N2o, larger intake or a short block build in the near future go with the stage 3 version with the aftermarket valve. You can send us your castings to port or we can sell them to you outright. The intake will be fine or the 01+ LS6 style |
| All times are GMT -5. The time now is 04:16 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
