wasted some rod bearings, now what?
so built my engine from bottom up about 4 years ago. I put 1000-1500 miles on motor with no problems or any signs off issues. This year i went boosted and did some dyno pulls, maybe 500 street miles, and about 10 track passes. Last weekend i was out doing some weekend pulls and noticed a slight knock off idle and also noticed the factory oil pressure gauge was fluttering between 20-40psi. My autometer oil pressure gauge tee'd into the oil filter housing stayed rock steady at about 40psi the whole time. Knowing that something was wrong i babied it home and proceeded to drain the oil and inspect the oil filter. Upon cutting the oil filter open i found quite the collection of bearing material. So i pulled the engine and started to tear it down and found the problems with #1 rod bearing being trashed and the rest weren't far behind.
engine build list:
stock crank
melling hp oil pump, new dumbell, new cam retaining plate
clevite main and rod bearings
compstar i beam rods, arp rod bolts
mahle -16cc dish pistons 3.905 bore
243 heads, arp studs, ls1 mls headgaskets
was running 15psi of boost when i started having problems
on3 78/75 turbo
here's some pics of the carnage.
so where do i go from here??
Can i just clean the crank up and install new bearings?
Does this look like the bearings failed due to a clearance issue or could there be another problem?
Should i pull the main bearings and also inspect the cam bearings?
Should i pull the heads and pull the rod/pistons out to have them checked?
TLDR: destroyed #1 rod bearing, other bearings not far behind. What could be the cause? What should i do to correct it?
engine build list:
stock crank
on3 78/75 turbo
Definitely need a total teardown to get all the **** out of it.
My guess is perhaps the rods were a bit tight from the onset and the boost accelerated the bearings eating themselves to death.
I'm thinking the crank should be reground but after inside measuring some new 010" main/rod bearings to properly set the clearances.
Obviously new oil pump/valve springs etc.
thats what i dont understand, i always had great oil pressure on both my factory and autometer gauge. I tore the engine down completely tonight and inspected everything. The cam bearings and cam looked great. The main bearings had some scratches in them and some spots of copper were showing. At this point im just going to send the block/crank/rods to the machine shop and have them clean and check everything. The pistons and bores looked awesome so atleast thats a plus.
to be honest i dont remember as i built the engine 4+ years ago. I do remember using plastigauge and the bearing clearances were in spec. Or are you asking what the bearing clearance is now?
Are you running a stock oil pump? I'm with RockinWs6; it sounds like a lack of oil volume/pressure. Especially when you're taxing the motor with 1atm of boost. Look into cleaning and rebuilding and include a high pressure oil pump. I have one from Melling and its rock solid so far.
So I have been questioning what pump to use this go around.
