Cam gear diferrence 1 Attachment(s) Is the any difference between these two cam gears? Do they have different cam sensors? Do they have different crankshaft sprockets? Attachment 642764 |
Yes. Yes and no. No. |
the one with the holes is for a gen III using a block mounted cam sensor the one with the bar cast into it is for a gen IV with a 24x crank using a front cover mounted cam sensor |
Actually the one on the left is from an 05 LQ9 with the cam sensor on the back, sorry I didn't specify. The reason I asked is because I'm intalling the LQ9 in my 98 TA and I don't know if I should keep its cam gear or change it with the older with holes on it. |
Originally Posted by ALPHA Q
(Post 19046706)
Originally Posted by KCS
(Post 19046809)
With the cam sensor in the back, it doesn't really matter which one you use.
(Post 19046706)
Actually the one on the left is from an 05 LQ9 with the cam sensor on the back, sorry I didn't specify. The reason I asked is because I'm intalling the LQ9 in my 98 TA and I don't know if I should keep its cam gear or change it with the older with holes on it. Wasn't really sure your purpose of asking. |
Thanks for the info KCS and Thunderstruck507. |
© 2024 MH Sub I, LLC dba Internet Brands
