Experiment: Cam Motion Low Lash Solid Roller with stock rocker arms
#161
he also pm’d me
happy to report everything is still all well, I probably should have the valve spring pressures checked or simply replace them
I adjusted lash again back in December because the engine was ticking a little. 1 rocker needed .003” removed. All the rest were fine
I don’t make it on here much these days but I’ll still say I am very pleased with the setup and would totally do it again
The following users liked this post:
NAVYBLUE210 (06-27-2020)
#165
He also pm’d me
Happy to report everything is still all well, I probably should have the valve spring pressures checked or simply replace them.
I adjusted lash again back in December because the engine was ticking a little. 1 rocker needed .003” removed. All the rest were fine.
#167
I have changed jobs again and now work for a major semi truck dealership dealing parts currently with hopes to move into lower management within 6 months. Things are looking promising.
If things go well I’d love to get the Chevelle painted, get some a/c in it, then possibly down the road look into a fresh engine setup. My buddy who works with me just put a bigger blower on his gt500 and now makes around 650whp, so I need to step up a bit haha.
#169
To further clarify, literally the last time I checked lash was when mentioned in this thread, which was quite some time ago
Also I had abandoned thought of this thread, transmission failed in my truck and I got stuck driving the Chevelle daily in the coldest part of winter...0-10* days, caught in snow/sleet a few times with a half working blower motor...the engine tick was a “last straw” on my nerves so I didn’t pull a .001” at a time...I just pulled .003” and the rocker went tight so I called it good and went to bed.
If anything I would suspect wear on the pushrod tips, rocker arm tips, or the beginning of trunion wear over damage to the cam or lifter given the components at play
Regardless, should any component fail I will for sure make a point to update. Given the amount of time passed and abuse seen I still call this experiment a success and thank Kip for convincing me to tear down a perfect running engine to try it.
Also I can’t remember if it was covered here but when I say abuse I mean it, I started experimenting and turning the engine 7400rpm at the track and on the street there were a few occasions it saw 7600rpm by accident (it still felt strong and I was focused on things other than gauges) as evidenced by my gauge recall function. I think 7640 was the high score.
Darth_V8r (06-25-2020)
#170
As far as tedious install, I overcomplicated it IMO. Once you have a good pushrod measurement it’s just a matter of the initial shimming. The valve stem grinding I did is not a mandatory thing given how well the shims work if you separate the rocker pedestals into pairs like I did.
#171
Moderator
Received 1,851 Likes
I can’t honestly say off hand, it’s been so long I will need to reread and check my notes.
#172
The pushrod measurements were absolutely the most critical part. Manton will usually get them within .003. The third time I did a LLSR with fixed rockers, I ordered the pushrods .010 long. But it was 7 at one length, 3 at another, etc. By ordering slightly long, you avoid the accidental "this one's too short and I can;t close the gap" issue.
#174
Long time no post
This time last year I was on the way to the strip and the engine developed a tick. Borrowed a trailer and got the car home. Have determined it lost a lifter or cam lobe on cyl 1 intake.
Will update once the engine is torn down. Will be getting a full shortblock refresh. I have a set of z06 243s with sodium valves to get cnc ported and yella terra adjustable rockers to go on with the new setup. I scored the parts cheap from a friend and also got his llsr. Undecided on using his cam or calling Cam Motion for one similar to my old one with more lift allowed by the rockers.
will update with pics upon tear down
The following 4 users liked this post by thunderstruck507:
#175
Good to see you posting Thunderstruck. Keep us in the loop here.
G Atsma (03-10-2024)
#177
The first lifter on driver bank lost the roller entirely.
Shockingly the cam sufferred very little damage but did have noticeable wear. Sent it back to Cam Motion so they can inspect.
Plans changed. I stumbled into a 406 LS2 stroker. Sent the ls6 243s to Katech for cnc, hand blend, and valve job. Using Yella Terra 1.7 full roller rockers with larger studs. And of course a new Cam Motion LLSR.
248 .637/ 256 .621 112+3.5
heads milled .020, .027” cometic gaskets, pistons are 15cc dish. Compression is between 10.8-11.2 depending on calculator
Hoping this new combo knocks on 500whp and a ton more torque.
