White steam/smoke puffing from oil cap/dipstick
Hey guys,
I picked up a 99 Trans am ls1 with a v9 vortech supercharger and I'm having a problem that might be bigger than I'm hoping. It's low miles, 40k original, but I'm pretty sure it's been driven hard as its already has a new trans put in. I got it pretty cheap so that much is good.
Here's the problem... It blows a lot of steam from the oil cap and dips tick (if I open them whole running). It does it when it's cold and hot. More when hot. It's a lot of steam and it is puffing out like a steam train. Comes out the exhaust too. A decent amount of condensation out the tail pipes. I replaced the oil and didn't see really any water in it (no fluid water or milkyness) except just a very small amount on the dip stick. Nothing obvious as far as oil in the coolant either. It's white steam, not blue smoke. It seems to run fine and have full power. The car has sat a LOT over the last few years so I understand it could be just condensation working it's way out. But it's a lot of it. And the pulsating puffing leads me to believe maybe bad rings or something? Any way to tell before having to do a compression test? (since the blower is there, that will be a pita. No room)
Is this something that I should be really concerned about? Or just let it be and see how it does? I haven't driven it barely at all since I got it (when I didn't notice the problem and drove it 200 miles fine)
Moderator
Received 1,835 Likes
Moderator
[QUOTE=Davy Bass;19095989]Hey guys,
Sounds like ur crankcase pressure is building and escaping where it can.
I had the same issue with a old SBC when the PCV system got plugged up.
I heard from a prior, prior owner that it had a blown piston ring on one of the cylinders. It makes sense. I would occasionally get a misfire cel at high rpms too. The car also had some oil residue in the engine bay.
I actually sold the car a long time ago now while it was running pretty normally. I never drove it hard so I didn't have any problems with it really. It will probably need a rebuild.
I hope for the next buyers sake that that's wrong but it makes sense. Course the guy who sold it to me like that lied so I guess I can't take all the blame...
