How strong are factory flat tops?
How strong are gen 3 factory flat top pistons?
I'm building a TVS 1900 L33 5.3L
My goal is 400-450rwhp (8-10psi) and use as my daily driver.
Can the stock 5.3 flat tops take that power reliability?
unfortunately the L33 has 9.9:1 compression
LS2s and LS3s with their higher compression are just fine at those boost levels, so yours will do even better. And the thicker liners will help also.
Lol leave the stock pistons alone just run good fuel and get a good tune. Yall play it too safe I have a year on my 5.3 and 12-13 lbs of boost running 10s on a stock bottom end stock pistons stock rings never touched the bottom end lol
I know a guy who will do the thermal coating and anti friction for $50.
Cheap insurance that the pistons won't go boom
A good tune and proper fueling will go further in keeping your pistons alive. Not saying those thermal coatings aren't good, but they are not there to prevent piston damage. They have their benefits of course, mainly in efficiency and power making, but they are not to make the pistons stronger.
Here's my take on this: if there's an issue with fueling or spark or cylinder pressure, no amount of thermal coating is going to prevent the pistons from going "boom".
Like from running too lean.
Strength is definitely affected by heat.
I probably don't need it, but for $50 why would I say no?
the importance of a tune that errs on the rich side can't be stressed enough
(also consider that it has been found that the rear cylinders tend to run leaner/hotter)
My take on the thermal coating is the added resistance against heat.
Again not saying those aren't worth it, but they are not done for protection against otherwise catastrophic damage. As long as that's the mindset you're going with then it's ok. But if you think that a coated stock piston will be stronger and handle severe conditions better then you're going to learn otherwise quickly.
I just pulled my L33 apart after two years and 80 passes. Most at 15 psi and the last ten or so at 18psi. I am upgrading to forged.
Everything looked the same as when I assembled it. No additional scuffing (they were fairly scuffed as received) rings all free.
They are amazingly stout.
I run E85 at 11.5:1 and 16 degrees timing. No detonation in the logs and the plugs always look excellent.
Guesstimating 800 rwhp based on performance.
Ron
Ron
Ron
Ron
Ur setup is far more aggressive and didn't go boom.
