Any independent flow bench numbers on Dart 215's?
It's possible I may have some flow data from many years ago (2005)?? on one of my flash drives. (Will try to locate)
These were the 205's when Dart was Dart!
We flowed them prior to hand porting and after. To my recollection as stock they flowed similar in stock form to a stock 243.The intake side with better flow from >.400. The exhaust side was better from >.200.
My buddy was very impressed with the chamber design and the standard production valve job. (Seats were very nice) We saw the same craftsmanship on a set of Dart pro 1 BBC heads that were on my 454ss pickup. (Hence my above statement about Dart was Dart.
Don't hold me to it but will try, and locate that old scanned datasheet.
I bought a set of as cast Dart 205's from Texas Speed when they first came out. At the time, TSP had flow tested the heads I bought and posted the results. Might turn up in a search but you could also contact them about the flow numbers. I was working with Jason at the time and they flowed the heads themselves and the results were lower than Dart's numbers. I have e-mails with Jason about this. This was in November/December 2005.
Found an old thread here: Dart Intake Flow Numbers from TSP
There's a red SS on YouTube that has several vids. He's running the 205's with a big cam, fast intake and 4.10 gears. It runs damn good for what it is. I'll see if I can find it here in a few
