408 LS Stroker NA Cam choice?? Which one?
So 2 cam profiles have been recommended by very well know cam profilers ;-) not going to name names! BUT the profiles are IMO alot different yet both seem to think they will make 500+ rwhp an be very drivable.
Specs:
236/248 .620/.603 114+3. Said power would come in early too... Hmmm
OR
XFI 230/236 .612/.6xx 114+0. Seems power will def come in early on this IMO
What would you choose?!
Specs:
OR
L92 heads hand port & polish exhaust ports only. Livernoius .660 spring setup with titainum retainers. But stock valves
Fast102 not ported
Ported ls2 throttle body
52Lb injectors
T56 ctsv 6 speed tranny w/ monster stage 2 setup
06 cts-v stock rear end for now
Fast102 not ported
52Lb injectors
The first choice has 14 degrees of overlap. I would not want this in a street car/6 speed. The second choice has 5 degrees of overlap. If it were me either go with the second choice or have something spec'd in the 8-10 degrees of overlap range. 14 degrees would be a little much for me especially in a 6 speed car.
Thanks for your input josh
Out of those 2 cams listed I'd do the 1st one for sure. I have 15 degrees overlap on my cam and with 4.10s and a 6-speed it drives just fine. What's your compression?
That's exactly my compression as well. Just my opinion but you have some nice flowing heads with a great intake and good compression, and having 408 cubes on top of it the setup would be very suitable to a fairly aggressive cam like the first one.
Originally Posted by HCI2000SS
Haven't had it on a dyno with the new mods, but I estimate it around 450 rwhp n/a
So if this 408 dont drop 500 ill be a bit upset although dynos I know are ONLY numbers but still im baseline comparing with what i have now an fell going to 408 with better heads an cam should produce 80 more hp i would hope....
Oh man if i dont get 500 im gonna be disappointed! Lol. Only because my stock bottom end ls2 heads cam car is putting down 421/413 now NA.
The following users liked this post:
Rassie (08-27-2022)
Gotcha. I don't know man a 80 hp jump might be a little generous lol. I'd go back to the same dyno to get a fair comparison. Don't see to many people running Howards cams on these cars. That's what I'm running as well, and really like it
Rassie (08-27-2022)
