How many layers for 0.110 MLS gasket?
After fubaring my block and getting it decked, it seems I need a 0.110 thick head gasket at minimum. Since this is going to be custom, and I might as well use options.
I have heard thicker MLS gasket tend to have issues. Since I am not limited to off the shelf sizes at this point, how many layers should I use?
Cometic can custom make a thickness for you if you want use a single MLS gasket, here is a .120 MLS. Or you can stack no MLS gaskets but I dont know how well that would work at .110" thickness.
http://www.jegs.com/i/Cometic-Gasket...5-120/10002/-1
