Build I put together. Any suggestions or input is appreciated.
Moser 12 bolt w/4.10 gears
Yank SS4000 Stall Converter
Hooker Blackheart LT Headers and TD exhaust
FAST LSXR 102mm Intake Manifold with billet fuel rail
Racetronix 42lb./hr fuel injectors
Aeromotive A1000 Fuel Pump
Williams 102mm Throttle Body
FTP 104mm air lid
Texas Speed 100mm MAF
PRC 227cc CNC Ported Heads
Texas Speed MS4 camshaft
Trunion upgrade kit
Texas Speed Chromoly Pushrods
FTP 104mm air lid
Trunion upgrade kit
I'm not super experienced on custom cams. I just figured since you have a pretty nice list of high end parts that you'd have one specced out for you. I bet if you talked to Cam Motion or TSP themselves they'd come up with one that isn't too far off from the MS4 but a little more optimized for your build.
I may try and talk to Cam Motion and get back in touch with TSP, I talked to TSP and they mentioned the MS4, but I'll ask about a custom cam just for these heads. Couldn't hurt anything! Thank you for the advice, like I said in the title input is appreciated.
I agree. A custom cam is not that much more and in some cases the same price. Geoff Skinner at EPS is also a very good option. His lobes are easy on the valve train. You may want to throw in some Yella Terra rockers and some 3/8 pushrods.
If you're doing the trunion upgrade, go ahead and go with the Straub bushing kit.
Double check if you have the clearance for 3/8" push rods, some heads have to be clearanced for them to fit.
With the list of parts you're putting together, you might want to upgrade your fuel pump with a 340LPH pump, Racetronix makes a great one (IMO).
When you go over your setup with whomever your going to spec your cam with, ask them if the 42# injectors are going to be enough. With the setup your describing, I would go with something a little bit bigger (I could be wrong though...). Just be safe before buying them and get an expert's advice.
I personally would go speed density and save on the MAF. You'll never know the difference other than a little more throttle response with SD. And I'd avoid those injectors. I had a 2500rpm misfire with two different motors that I couldn't figure out. Sure enough after I went to FAST 36s the misfire is gone. Most tuners just rape the IFR table to make those work. Your better off buying an injector with data available.
