LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Swapping from 241's to 853's (https://ls1tech.com/forums/generation-iii-internal-engine/1842985-swapping-241s-853s.html)
josh2002-ws6 Aug 23, 2016 10:40 PM
I have a 2000 SS that has 350k miles. The drivers side head has now thrown 2 spark plugs in the past 6 weeks. They are stock 241's. I'm pretty sure they are just worn out from the mileage on the motor, it is 100% stock. Instead of putting another helicoil in I am just gonna swap the heads out with replacement lower mileage ones. I can't seem to find that many low mileage replacement 241's but have found a few 853's. If I switch, do I need to change or look at anything else? The car is staying stock, so don't suggest looking at anything else. Thank you.
A.R. Shale Targa Aug 24, 2016 01:53 AM
If going through all that work, I'd pop some new lifters in there and a set of stock unmolested 243/799 heads
HCI2000SS Aug 24, 2016 03:24 AM
Exactly!
Tim john--- Aug 24, 2016 05:16 AM
I do not have the mileage Josh has but am curious as well. I have a stock 2004 GTO LS 1 with the stock/factory 241 cylinder heads on it, will the 243's be a direct bolt on, I mean will everything else fit, align and perform as intended. (just do a head swap) Engine is factory stock. Thank You.
Tim john---
farmington Aug 24, 2016 08:14 AM
as long as the heads haven't been cut on the decks you're good to go. if they have been cut in the past might need shorter pushrods
Darth_V8r Aug 24, 2016 08:31 AM
If you put the 243 on you can use MLS head gaskets. If not, use the composite gaskets. There's a notch on the 853/241 heads that won't deal with MLS
kinglt-1 Aug 24, 2016 09:41 AM
I posted the same thing then deleted it because of the snarky last sentence. "don't suggest looking at anything else"
A.R. Shale Targa Aug 24, 2016 09:54 AM
I thought the casting notch was only on 97-99 perimeter bolt v/c styles ??
A.R. Shale Targa Aug 24, 2016 09:56 AM
Kings tend to be a bit snarky cuz; well......they're kings. :cheers:
Darth_V8r Aug 24, 2016 11:01 AM
nope. I have center bolt style. It's on them too. And into some 2000 models. That's why I mentioned it. OP should look for the notch and purchase gaskets accordingly
Tim john--- Aug 24, 2016 11:32 AM
What kind of performance gain could one expect with the swap from 241 heads to the 243's, all else being factory stock on a 2004 GTO LS 1 engine sans Hooker/Holley Blackheart mid length stainless steel headers. Being the compression would go up a tad would that be an issue w/ fuel, computer tune as is ? Would the 2004 LS1 GTO fuel rail covers still fit (2004 is different than 2005/6). Thank You.
Tim john---
Darth_V8r Aug 24, 2016 11:37 AM
You'd gain 10-15 hp and about 1 mpg from the compression. Tune will be ok, but you'd gain from tuning ass swell
Tim john--- Aug 24, 2016 11:39 AM
Thank You very much Darth, appreciate you taking the time.
Tim
RPM WS6 Aug 24, 2016 01:39 PM
1998 was the last year for perimeter bolts (806). '99+ (853/241) are center bolt.
© 2026 MH Sub I, LLC dba Internet Brands
