5.3 gen IV rods and Pistons in gen III
So I have 3 gen 3 iron 5.3. I want to put one in an s10 I have. So someone gave me some 5.3 floating rods and Pistons. Will these go right in the gen 3 or so I have to have crank balanced. I've seen guys throw 4.8 flat tops on rods reuse bearings and run but not much info on the whole rod and piston assembly from gen IV. Has anyone done this. I guess it be nice to pull dish Pistons and throw in the flats and roll. Just looking for some input.
Like mentioned above it would be a good idea to have the assembly re-balanced.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Has anyone ever done this with good results and longevity? Can we hear from the people that have tried it and seen good or bad results. Same situation but going with gen 4 rods and Pistons that are l33 flat tops. from gen 3 rods and standard dished Pistons.
Gen 3 rod and dished piston weight and gen 4 rod and flattop piston weight
About 40 grams or 1.5 oz. difference. Gen 4 heavier. I'll have a better idea sat. Of what just the rod differences are. Gotta get piston pressed off first.
