216/220 .525/.532 XE-R lobe expected spring life
What type of spring life can be expected on a daily driver with above said cam? Please mention what springs you are referencing as well. I'm tempted to have comp grind this xfi cam on an xe-r lobe for a 2002 5.3 getting bored for Ls1 pistons and stock heads.
Guess I'm getting mis information about what to use on my setup. I was told the xe-r love would be better for under the curve power, which is valid but I suppose they forgot about the daily driver aspect.
That aside, what comp lobe would you suggest? This is for a truck not a car also.
I was also under the impression a 216/220 is about the biggest you would want on a daily with stock 02 heads. To keep from losing to much low end or requiring a relatively high stall to the point it kills mileage.
Take a look at the offerings from Cam Motion. Their lobe profiles are known to produce power without beating the hell out of the valvetrain. They have some shelf offerings designed specifically for trucks.
I am not saying you can not run a XE-R but it does not make much sense when there better options today. If you want to run a older Comp lobe then stick with the XR...
Part #54-424-11
212/218 .558 .563 115
any bigger then this and you will be trading low end tq for more mid range and upper rpm power.
Part # 54-426-11
222/224 .566 .568 112
This will still work with a stock stall and gears.
I wouldn’t run an XE-R lobe on a daily. The HUC COMP lobes have super mild ramp rates.
I’ve run the Trick flow 216/220 @ 114. Price is right on that cam ($260ish), but I think it would be lazy on an NA 5.3… It was lazy on my 6.0 anyway. I’d want a much tighter LSA on a small bore NA SBE personally. 112-110 LSA would be much more responsive. Pretty hard to beat the 212/212 @ 112 .565 lift triple 12 from JFR for overall performance.
If you want a snappier cam with a more aggressive sound, 220/220 @ 111 .510 from edelbrock (PN:2215) sounds amazing IMO. It had better throttle response than either of the cams I mentioned above. It only pulled 10psig or so of vac at idle, but that’s not horrible. Also the Howards version of the GM hot cam would be another “mean sounding” low lift cam that wasn’t super hard on the valve train. I just picked up that grind to try on my new 5.3.
I'm partial to running comp since I get cams directly from them at below dealer cost.
Is there a comp lobe comparable to the ones you guys mentioned offered by other companies?
Ask them to use a mild ramp rate lobe.. like the HUC.
This cam could be decent form them... and has a mild ramp rate with healthy lift.
http://www.compcams.com/Company/CC/c...csid=1399&sb=0
Restricted User
My point is that with a cam that small and that low of a lift, even an aggressive lobe isn't going to be very aggressive, and gains are going to be very small, im talking counting on one hand small. You're overthinking this.
Once you get into cams with 230+ duration and .600+ lift, then you can worry about lobe profile.
LS1Tech Premium Sponsor
We offer two versions of the 216/220 cam on our TSP lobes which are much more stable and valve spring friendly. We offer a low lift version (.550) that can be used with GM LS6 springs and a higher lift version (.600) that can be used with PAC 1218 springs. Personally I would run the 212/218 cam vs the 216/220 on a 5.3. I have dyno graphs between the two that I can send you showing you the power differences and where one gains over the other. If you have any questions give us a call at 512-863-0900. We would be happy to help.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Lonnie
Lonnie
You're right I missed that part. We have several options for your build. We offer low lift lobes all the way up to 228° of duration and our .600 lobes are amazing in power and stability.
Lonnie
Lonnie
__________________
Lonnie
Lonnie
Also curious myself.
I only saw one that shows there 212/218 Vs. stock. https://ls1tech.com/forums/dynamomet...51hp-gain.html
I would like to see the dyno sheet comparison between the 2 listed cams as mentioned.
