LS1/6 Cam Install Gasket and Oil Pump Kit
Everything you need to complete an LS1/6 cam swap!
Camshaft retainer plate Gasket with hardware
GM front timing cover gasket
GM front crankshaft seal
GM water pump gaskets
ARP Cam bolts
ARP LS1 Crankshaft bolt
GMPP LS2 timing chain
Melling high pressure standard volume oil pump
Total for LS1/6 Cam Install Gasket and Oil Pump Kit: $269 includes free shipping.
In stock and ready for immediate/same day ship out
310-326-2399
or
parts@americanheritageperformance.com
http://www.americanheritageperformance.com
310-326-2399
or
ARP Cam bolts
310-326-2399
or
310-326-2399
or
The 243 heads will gain you more power over the stock ls1/853/241 heads but you will still pickup decent gains by just doing a cam even if you're running stock ls1 heads
