Gen 4 Pistons/Rods w Gen 3 crank, Rebalancing required?
Rod and Piston Weight
The best "tech" would be for you to weigh the rod/piston/pin/rings from each engine assembly.
You could "bribe" a USPS clerk, let them use their scale.
My guess is that could be possible, they are very kind.
They are required to to "quote" shipping charges.
You could visit a "dispensary", I am sure they have a Gram Scale.
The "new" weight can be lower, not heavier.
Lance
Lance
Moderator
It would be smart to have the crank balanced. The LS2 rod and piston assembly is considerably heavier.
Gen III LQ4 Piston, Pin, & Rings @ 649g:
Gen III Rod @ 609g:
Gen IV LS2 Piston, Pin, C-Clips, & Rings @ 665g:
Gen IV Rod @ 642g:
When you calculate the bobweight, the difference is almost 60g. Normally a crank is balanced within +/- 2g from a target bobweight.
Gen III Rod @ 609g:
Gen IV Rod @ 642g:
Spend the money and have it balanced.
__________________
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
The following users liked this post:
Homer_Simpson (12-04-2021)
