LS .040 head gasket options
Old 03-09-2017, 11:07 AM
98redorangeta's Avatar
Default LS .040 head gasket options
I am looking at head gasket options for some 243s. I see cometic is making a 3.910 bore .040 gasket and Fel-pro makes a .041 gasket but I can't find it in a 3.910 bore?
What are you guys doing for the thinner gaskets on stock bore LS1 and Ls6 stuff?
Old 03-09-2017, 11:16 AM
Super Hulk Smash
JakeFusion's Avatar
You can run the larger Fel-Pro. It slightly lowers the compression but works fine.
The Cometic is very good though. I run that one.
Old 03-09-2017, 11:55 AM
I figured it wouldn't be an issue to run the bigger bore as I have done it on the 317 heads before.
I did see in the calculator I was using that I only get a .2 bump from a 4.1 bore and I get a .3 bump in CR with the 3.910 bore figured I would take the extra .1 by getting the smaller size if they made it.
Old 03-12-2017, 10:20 AM
64post's Avatar
If you can't run the the 3.910 because of your bore size there is a 3.970" Or maybe have some custom size ordered. Avoid going too much bigger than your bore size,^ compression ^ and contaminants for incoming mixture.
Old 03-12-2017, 10:43 AM
BullyDawg's Avatar
Subscribed. I also need .040 stock Ls1 bore gaskets.
Old 03-12-2017, 11:11 AM
98CayenneT/A's Avatar
https://www.texas-speed.com/p-182-co...3910-bore.aspx
Old 03-12-2017, 01:00 PM
sxc Z28's Avatar
I was looking at this stuff yesterday make sure you see they are sold separately not as a pair.
Old 03-12-2017, 01:26 PM
Super Hulk Smash
JakeFusion's Avatar
BTR also has them in multiple bores and thickness options:
https://www.briantooleyracing.com/co...d-gaskets.html
Old 03-12-2017, 07:33 PM
slogo's Avatar
Not MLS but cheap and sold in pairs. http://scegaskets.com/store/chevrole...-chevrolet-ls/
Old 03-13-2017, 04:54 PM
Thanks guys seemed like everyone is doing cometic got some coming from ws6 store. I have always heard good things but wanted to make sure I wasn't missing new and better options.
Quick Reply: LS .040 head gasket options
