223 sportsman heads and cam mamo build
Old and new tune
Edit... FINALLY posted some pictures... This is the second time ive built this motor. 02 z28 camaro 6 speed with 9" rear with 4.11 gears. The first build I put in scat rods and mauhle -4cc pistons. all arp bolts. tv2 cam, 243 heads, ls7 lifters 7.4 pushrods and ls6 intake. decked the block and milled the heads. Motor had 10.9.1cr. kooks 1 3/4 headers with true dual 3" dumped. With a Pat G tune it made 438/405.
After breaking a valve spring and finding helicoils in my rocker bolt holes (not being able to tourque the bolts down) i replaced all the springs and two helicoils that come out put it back together and after two weeks the bolts popped out... My wife told me to just go ahead and buy the heads i wanted so that is when i found Tony Mamo and his new sportsman heads...
After tony schooled me on a few things I ended up going with the sportsman 223 milled to 56cc with hollow valves and yella terra rockers... few weeks later I told my wife i need a cam to match these heads, so I got tony to spec one out for me... 235/240 615/620 113+3 cam. cosmetic .054 gasket for 11.4cr and also went ahead and ordered some short travel johnson lifters and measured the pushrods for a few different custom sizes... the kicker with all this is i still have my ls6 intake and change my exhaust to 2.5" dual with x pipe all the way back through single chamber mufflers and cme.
So now that it runs and drives (by the way tony it sounds great!) I have contacted Pat G to get another tune in, hopefully to get some better numbers under the curve as well as at the top!
I'm keeping the exhaust like it is or will go to 3 inch. I wanted duals all the way out the back but also wanted to lower the car some so that's why I went with 2.5", the intake will be when I get some bills payed off. Also have my first baby due in about three weeks so that will put a damper on getting a intake. I'll get a video soon, probably this weekend
It's just a custom setup. I did a lot of research and screenshot pictures, bought the single chamber mufflers, x pipe, and CME off eBay then brought it to a shop and they did it lol... If I would do it again I'd probably go with speedenginering. I had there headers on my last car and liked them alot I figured the duals would be nice also as well as affordable
Well brought it to Pat g. They have updated the dyno since last time I brought it. They told me it read about 5% less than most other dynos. Also the motor was not getting enough air. Results better heads and a bigger cam 432hp/409tq. Lost HP gain a few tq. Guess it's time for a fast intake now
Driving wise from a roll at 2000 rpms 1st gear blew the tires off in 1st 2nd and 3rd with nito 555s the last build from a roll like that would barely spin. I wonder what the fast intake would do on the 243 heads vs the Mamo heads. I would think that the 243 heads were peaked out almost where as the Mamo heads are starving for air.
Let me know if I am not interpreting the graph correctly.
Yes, correct. The old set up had more HP and tq at the 2200rpm... But the old set up was also on their old dyno set up. They said the new computer on the dyno is very stingy and if I would to bring it to Houston it would read 5% more. So if that's true the dynos in Houston would read around 453hp and 429tq
