Help ID these LQ9 rods and pistons....
Looking to possibly buy these....the owner "thinks" they are 02 or 04".
I have a fresh 04 LQ4 I'm wanting to put some flat tops in...I know the pics aren't great, but all I have. Are these the "better rods" with the dimple? Are these the floating pin style? Are the rods any better than my 04 LQ4 rods? Can I just put the pistons on my existing rods?
Thanks for some quick responses, they won't last long on this FB page....
Super Hulk Smash
If you have the Gen IV rods already and you're going to swap heads, there's no reason to do it. You can just set your head chamber to get the compression you want... unless you have to mill a lot more than you want to get there... and then the flat tops would be beneficial.
So I guess it depends on the heads you want to use and whether they start at 65cc or 70cc and what you want do cam-wise.
In this other motor I was wanting to put some AI 243's, flat-tops, ported FAST I have, and matched cam and get to 11:1....P/V is what I don't know much about.
I know the whole cathedral vs rectangular port debate, so was wanting to do my own test on which would make more power on a SBE LQ4. This too would be an all out drag motor, no street manners needed
Yesterday I picked up some never run 799's from a crate motor, for a song I think I'll pass on the flat top pistons and make up the 10 hp difference somewhere else. Plus, why tear back into a fresh rebuild?
Any opinions on how much (if any) to mill the 799's and a BA cam choice?
I will most likely contact some of the gurus, just anyone with experience with this combo would be great. Thanks,
