Bought a 2000 SS but it has a different motor
Bought a used 2000 SS Camaro and went to tear down the motor today for a cam swap and noticed it has 706 truck heads and an iron 5.3/4.8 block. The guy has obviously misled me in the sale so I'm considering taking him to court over the inaccurate listing and recovering some of the value difference. My question is, will my 3 bolt cam fit in the meantime? What value differential and pros/cons do I have at this point? TIA
The iron block would have been obvious by way of its darker color than an aluminum block. It's always good to thoroughly inspect any vehicle purchase for implied content.
I can understand where you are coming from. The block on mine looked fine when I bought it, but upon closer inspection it had some 862 5.3L truck heads on it. I knew the motor had a cam and truck heads being used on LS1 blocks is pretty common. It pulls hard so I am not worried about it. I did check the block and it is indeed an aluminum LS1 or LS6. That I'm not sure on and I'm not sure it's the original engine either, but it's at least an LS1. When I saw the 5.3L heads I initially thought the worst.
Honestly, a truck block isn't all that bad. Those 5.3's are tempting replacements because they are similar performers and they are plentiful due to coming in the trucks. You can also bore them out to 347CI and essentially create a LS1 with an iron block in a sense. They are good for boosted applications as I understand it.
I do think it does devalue the SS slightly, so depending on how the car was represented and the price paid, you might have actual grounds to take the seller to court.
He sold the car as a recent swap from a 2004 LS1 GTO. So it should be an all aluminum 5.7l and instead I have a iron block 4.8 or 5.3. I bought the car on a rainy day and was honestly just too anxious to start on my project. I should have been more thorough but he clearly lied about the swap.
Good luck! Usually these sales are "let the buyer beware". In Ohio, you can waste your time taking them to court, and even winning, but getting them to actually pay is literally a big joke.
You might have better luck just taking him to court to get your money back on the deal. Did you call and point it out to the person?
Here in California, it would DEFINITELY be grounds for a lawsuit. It is specifically illegal to swap a truck motor into a passenger car here. And if the fact that this was done was not revealed to you, you could definitely go after the seller legally. Admittedly, a truck motor in a Camaro would probably pass smog because the swap is essentially invisible (ie the smog tech probably wouldn't notice just glancing at the engine if all emission equipment is there). But if you WANTED to use this as a way to legally pursue the seller, you could. Not sure what the emission laws are like in your area. But this is something to consider.
We aren't talking big dollars here seriously, but you were misled and in most states any judge would side with you. Is it worth fighting over? I'd simply ask for 500-1000 dollars back and see if they bite.
Honestly I'd rather have a cast iron block over aluminum<cheap made out of old beer can that nasty stinky old guys drank out of.
Cast Iron good made out of old bath tubs that hot chicks took hot bathes in....see my point?
He wouldn't gain a lot by doing this, but he might get something out of it. Whether or not you'd be able to do anything beyond breaking even in small claims court is debatable. I'd probably avoid it as it wouldn't be worth my time.
Eh....fair enough I suppose.
