Hylift Johnson B2148-LS lifters. Any experience with?
Does anyone have any experience with the Hylift Johnson B2148-LS lifters? They are easily found on eBay as a replacement gm lifter. From what I have read the preload is 020-.040. Are these a good lifter choice to be used with a btr stage III truck cam? How do they compare to the ls7 lifters?
I never heard of the Hylift B2148-LS Johnson lifters and that preload is very little so you will have to be spot on with all your pushrod measurements. Plus i have never seen Johnson lifters that cheap so they are probably knock offs.The morel 5315 drop ins are a nice replacement lifter for the gm lifters.
