Options for getting to 400Hp in z28 camaro
Just got a 99 z28 camaro 6 speed manual and was wondering where I should put my money to achieve more horsepower. It's a summer daily driver that I just want to be a little more faster. I was thinking 400 hp wouldn't be hard to achieve but I also have limited knowledge on the subject. I was hoping to not spend a whole of money but I also want the car to hold up to my daily driving. The ls1 only has 45k miles on it too.
400 flywheel or at the wheels? Big difference. Either way, it is very doable. An LS6 intake manifold(available used or Dorman repro), an LS6 cam (or one close to it, most aftermarket ones are actually better), and getting the heads ported would put you over 400HP at the flywheel. If it is legal in your state(I live in Cali where they are not), long tube headers will go a long way to making more power.
To get a close number, call either WS6 Store or Texas Speed and Performance. Either can help you do what you want AND keep the budget reasonable. They both have histories of happy customers, and are both sponsors of this site. All the best to you!
Just bolt ons and cam will het you there, or you could do a small shot of nitrous or supercharge it. Going that route it will drive like stock but have plenty of power when needed
Moderator
Received 1,835 Likes
400 at the crank with great driveability is easy and can be done relatively cheap. You don't even need to pull the heads. Here's my recommendations:
LS6 or used fast 78, 90 or 92 intake.
Port the throttle body
Titan2 cam from cam motion
Psi-1511 springs
Upgrade to 5/16 pushrods
Long tube headers if you can get past smog
Tune
That should get you to 400 rear wheel
Now other stuff I also recommend that won't necessarily improve dyno results but will register on the butt dyno.
If you have a manual trans, jump to 3.90 rear gear
If an auto, do a stall converter in the 3000 range and rear gears at 3.73
Psi-1511 springs
Tune
A cam with supporting mods and longtubes should me plenty to get you there. You can get a mild cam and drivability would not be affected. I would call one of the sponsors shops and have a talk with them.
LS1Tech Premium Sponsor
