AFR heads P/N 1510. Does the old 205's and the newer 210 Mongoose have the same P/N?
I picked up a 2000 Camaro with a built motor. I talked to the owner and it was unclear what he had for heads on it. He knew they where AFR but not the P/N. I took off a catch can that was blocking the P/N and it is 1510. I looked up the number and it comes up a AFR 210 mongoose heads. Problem is it also seems to be the P/N for the older AFR 205's. Any easy way to tell what I have here?
Call AFR about it. They might clear it up for you.
