LM7 with 228/230 cam build questions
But there are some questions still without an answer so I hope someone will bring their opinions for that kind of stuff I wanna build.
So I have to figure out what kind of pushrods should I use and a throttle body - should I have to port it maybe?
My engine is '04MY so it already has a DBW TB, also I have a cable TB from the LS6 intake (both are 3-bolt pattern) AND I also can get a 92mm FAST TB from my friend but it has a 4-bolt pattern and came off LS3 intake.
Googled an adapter and founded some (to assemble 3-bolt manifold with 4-bolt TB) but does it even work?
And I forgot to mention that I have 2 hasness kits - first one came off the Tahoe for the DBW (along with the engine itself).
This is not the best option for me because I would like to put my ECM behind the dashboard but not inside the engine bay.
And the second one came off '02 Camaro but Camaro had a DBC setup.
Althrogh I have only 1 PCM from '04 Tahoe (and I hope it can work with DBC, I'll theck it today).
Drive by cable setup is prefered because it's much easier to install just 1 particular cable instead of electronic pedal, black box and harness for all that BS. I have all that but would like to keep things simple.
Truck intake can not be used anyway because of hood clearance. Unfortunally.
There're pushrods and 3-to-4 bolt TB adapter plate left to figure out...
Cam specs are:
Lift: 0.585"/0.585"
Duration @ 0.050": 228°/230°
Advertised Duration: 283°/286°
Lobe Separation: 112°
Yeah but if only my PCM can run DBC setup...
Cam specs are:
Lift: 0.585"/0.585"
Cam specs are:
Lift: 0.585"/0.585"
Still no entries for a pushrods?
Ported and polished my DBW TB from LM7:
Assembled it with LS6 intake manifold, will be using motor's OE PCM and harness, I guess it needs to be rewired but thanks to lt1swap.com - found all the schematics.
Run the stock (7.4) pushrods thats what the sloppy cam is intended for. I recently did a identical build. The only difference is the intake (LS2). The engine n/a makes somewhere in the 330 rwhp range.
Gapped rings .25
ARP head studs
ARP rod bolts
228/230 cam
SLP Double Roller timing set
Pac 1218 springs
Ls1/Ls6 Head Gasket
Ls7 lifters
Ls2 oil pump
Ls2 pushrods
Ls2 rockers
Gto oil pan
Ls2 oil sump pickup
Oil pick up tube girdle
No machine work or anything special
ARP head studs
ARP rod bolts
228/230 cam
Pac 1218 springs
Ls1/Ls6 Head Gasket
Ls7 lifters
Ls2 oil pump
Ls2 pushrods
Ls2 rockers
Gto oil pan
Ls2 oil sump pickup
#32
Gapped rings .25
ARP head studs
ARP rod bolts
228/230 cam
Pac 1218 springs
Ls1/Ls6 Head Gasket
Ls7 lifters
Ls2 oil pump
Ls2 pushrods
Ls2 rockers
Gto oil pan
Ls2 oil sump pickup
ARP head studs
ARP rod bolts
228/230 cam
Pac 1218 springs
Ls1/Ls6 Head Gasket
Ls7 lifters
Ls2 oil pump
Ls2 pushrods
Ls2 rockers
Gto oil pan
Ls2 oil sump pickup
