My slow long-term 5.7 iron block LS1 going in an E36 318is build, NA 570hp crank goal
Hello,
I've been into this project over a year now( started 2016)
I purchased a 2002 Chevrolet avalanche 5.3 long block with 80k kms.
I stripped it down to the short block and sent it to the machine shop to get it bored out to LS1 spec. 3.898 in bore
I had forged flat mahle pistons with reliefs, and eagle H beam rods put in for my relatively high rpm build(7500).
I had chosen a comp cam 285LR-HR13 installed.
For intake and heads I have purchased a set of 52mm Jenvey ITBs, and stage 2.5 5.3L PRC heads with double springs set to run at 11.5:1 static compression and .660 lift.
Holley HP EFI for engine controls, full heating and AC amenities, power steering, 1-3/4" Long Tube headers, dual 3" exhaust, 3.91 rear end gears and TR6060 transmission.
What are your thoughts on this build? What kind of power so you think this will make? I have no plans of boosting this.
It'll be a while for me to save up more funds to continue this build.
My Jenvey ITBs without the trumpets attached.
Picking up my forged short block from the shop!
What is it going into?
Cool! Ought to be a BEAST!
