LY6 Shortblock with 799 Heads/Dorman LS2 Intake or go with LS3 head/intake
Alright everyone, I have some questions on where I should go with my setup. I'm placing this in the Gen 3 Internal forum for now. I was in the middle of building a Gen 5.3 iron block with 799 heads, Dorman LS2 intake manifold, and a 224/228 .581 .588 lift 112 LSA cam. Pretty mild NA build. This last week I bought a Gen 4 LY6 6.0 short block because I got an awesome deal on it ($260). It has I believe around 80k-90k miles on it. I need to have the cylinders honed because they have surface rust in them that can't just be wiped away with a rag with oil on it.
This is my question, how much would I be hurting myself power wise by sticking with my 799 heads, Dorman LS2 intake manifold, and 224/228 cam? Or should I try to sell everything and buy 823 heads, LS3 intake manifold and sticking with my cam? I am on a pretty tight budget but I also want to do this right as much as possible. In my head, which I essentially have is a 6.0 short block no matter if its Gen 3 or Gen 4. I know a lot of people are going with the LS3 style head/intake on 6.0's, however I have also read up on here that cathedral port heads are decent on a stock cube 6 liter. My motor will be NA and I'm not trying to make huge power (budget) but I would like to make really good power (450ish at the wheel). This is going to go in 100% street driven 1998 Camaro z28 M6.
Thank you all for your time.
I think for what you are doing with it, the 799 heads(identical to 243's) will do fine, even better if you get them a mild port job, but not totally necessary.
Agree on the cam, but for street use, much more cam would be a bugger to drive in traffic. But that's just me, maybe the OP is used to that! lol
As long as it is tuned to a "T", and I KNOW you probably have that down, you're right!
If on a budget; I'd just use oil and a scotch-brite pad to clean them walls and leave the short block together. releasing the rod bolts and re-torquing them can distort the big ends....I've seen it myself on a rod resizing machine...no lie
Have those heads milled like.030", pocket blend the bowls, sexy valve job, and pop it together with that cam
Might only make 420-ish rear wheel however the drivability and responsiveness
will make it alot of fun to drive
Depending on your vehicle weight, gearing, and other mods, I don't know that I would go too much more than 230/236 @.050" for a perfectly streetable drive to mexico tomorrow type combo
Tony Mamo made 475 RWHP with that cam and some 205 AFR heads on a 346" back in 2005
So I finally had time to do a closer inspection on my motor and I found that I had a couple of extra valve reliefs in two pistons...glad I got the motor for cheap. So these are my thoughts. I'm thinking of buying a set of LS2/LQ9 flat top pistons and running them with my 799 heads. That should bump my compression ratio to around 11:1. I know I should be safe with the cam I already have. If I upgraded my cam, what would be recommended? Or should I just call BTR or Tick up? Or just run the cam I have? Rather not have to cut valve reliefs if I didn't have to.
Whoa! Nothing like getting new valve reliefs while in use!
D n J hyper pistons can be had with rings for under 300 bills got mine from R.A. but the WS6 store carries them or the equivalent LQ9 ones with the slightly thicker ring pack...not huge money really....run a fine ball hone through them cylinders with Dexron for lube....clean well and put her together
