so how come the pistons at tdc aren't flat along the block deck
stupid question, i have my heads off and brought them all to the top one by one to clean off the carbon. i noticed when the pistons are tdc, the bottom of the piston (header side) would be flush or even with the block. but the top (intake side) would be slightly above the deck. so it would seem as if the pistons are kind of cocked or crooked inside the cylinders. why is this?
Great answer A.R.!
Not to mention that the LS series engines have offset piston pins, meaning that the pin isn’t exactly in the center of the piston. This exagerates the rocking that your seeing Floorman.
Pin Offset = Boost Safety
Hi Velle, Your answer ALSO, the Pin Offset. (good tech)
I fit RaceTec pistons with "offset pins" if the customer will allow the small cost increase.
SO I ask, why is the pin offset (OEM Side) IMPORTANT on a S/C engine ?
Lance
Lance
