RPMSpeed 5 ls engine test for 2018 (but wait there's more) - Page 5 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
Reload this Page >
Notices
Old 10-08-2018, 01:57 PM
  #81
LS1Tech Premium Sponsor
I like the pac1218 and 1219 they are high quality and super economical. From the performance above .600 range and higher than 6500rpms i really prefer the Manley. had a friend using them on a 200hp+ nitrous ls1 that would spin to 7k and it had 0 issues even spraying off the line. We used the comp 772 ti retainers which were just a tad heavier than these trick titanium ones.
The psi are good but lack a little pressure imo and are still the same price.
tech@WS6store is offline
Old 10-08-2018, 02:49 PM
  #82
OK, good spring info! I figured you would know. Good for all of us to have a shop that uses what it sells, and tells us about it! THANKS!
G Atsma is online now
Old 10-08-2018, 10:35 PM
  #83
LilJayV10's Avatar
I appreciate you bringing some truthful knowledge in here.
LilJayV10 is offline
Old 10-08-2018, 10:38 PM
  #84
Hopefully soon ill have truthful results!
Old 10-10-2018, 07:23 PM
  #85
I have been doing a lot of lurking and not commenting. I personally am very interested in the 5.1L engine, but in for all the results as its awesome to see somebody build something other than a 383 or 408.
fbodyfreakls1 is offline
Old 10-10-2018, 08:02 PM
  #86
I am working on acquiring an iron 5.3 block and will likely use one of the 5.3l blocks i have for the 5.1l. possibly the l33 block.
Old 10-10-2018, 08:31 PM
  #87
Darth_V8r's Avatar
Glad to see this project is still ongoing
Darth_V8r is offline
Old 10-10-2018, 08:35 PM
  #88
The only hold up for both the rod bolt checking and the 333 is the machine shop. The 5.1l will likely be next then the iron 5.7. Ill have a 6.0 iron also to do the 372 to actually test.
The all stroke 360 may be the last since its going to cost the most and ill need to possibly sell the other engines to fund it on the side. The all bore 346 will likely be January but i WILL get it done.
Cams should be out soon also.
Old 10-10-2018, 08:39 PM
  #89
I am doing oddball combos to show what is possible with our rebuild kits on a shoestring budget basically. It also serves 2 or 3 other purposes in showing what a large bore will do vs a small bore long stroke. And then of course the large bore short stroke 5.1 and 333 will prove our new cams and test the limits of a stock casting head.
Old 10-10-2018, 10:23 PM
  #90
I'm REAL curious how the 5.1 short stroke will do. That things gonna rev to the SKY!!
Old 11-28-2018, 05:00 AM
  #91
Can you post a link to some vids or pics of the builds thus far.
heykw is offline
Old 11-28-2018, 11:03 AM
  #92
The pictures in this thread are the progress so far.
They got sidelined waiting on machine shop plus a few other more important projects got in the way. I hope to have more updates soon though.
Old 11-29-2018, 12:14 PM
  #93
landstuhltaylor's Avatar
Didn't know you were doing a 5.1 but I'm very interested. Curious if it can make the power I would need, but if it can, it's a big weight break in the rules.
landstuhltaylor is offline
Old 12-02-2018, 09:35 AM
  #94
Thank you for doing these builds. Im interested in the 347 build as that sounds right up my alley for what im doing in my c10. Cant wait for results.
emfh is offline
Old 12-28-2018, 05:37 PM
  #95
...and spilling over into 2019. As soon as things settle down a little, youll see some progress on 2 or 3 of the engine builds!
Im excited of course. Im trying to tally up the budgets also to give you a good idea. Since nearly all of these are built with our RPMSpeed complete rebuild kits, its easy to keep costs down especially if you have the block, crank, rods and heads already!
Fingers crossed!!
Old 12-31-2018, 06:08 PM
  #96
New thread about cost on the 333 ls2. ill have updates here also soon.
https://ls1tech.com/forums/generatio...hine-shop.html
Quick Reply: RPMSpeed 5 ls engine test for 2018 (but wait there's more)
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
